Author Topic: Chained Rotation Parameters  (Read 2076 times)
basher76
« on: May 02, 2018, 01:34:11 PM »
Been a while since doing this, and I'm a bit stumped.
I have a north arrow block where I want the line and the letter 'N' to be able to be rotates via a grip, but I want the letter 'N' to always remain upright.
I've created two chained rotation parameters, which works, but if the block is rotated clockwise, the letter also rotates clockwise, and it should go the other way.
I can't figure out how to get that to work.
ChrisCarlson
Re: Chained Rotation Parameters
« Reply #1 on: May 03, 2018, 08:51:26 AM »
Try this
basher76
« Reply #2 on: May 03, 2018, 10:47:31 AM »
Eh, CAD version is too new for me to open, but thank you anyway.
I actually figured it out.  Instead of doing a linked rotate parameter on the 'N', I changed it to a point/move parameter linked to the overall rotate action.
Works a treat.
ChrisCarlson
« Reply #3 on: May 03, 2018, 12:32:15 PM »
Works a treat.
That's basically what I did, glad you sorted it out  8-)
