Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
Autocad Import command
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Autocad Import command (Read 2303 times)
hobbs1210
Mosquito
on:
April 22, 2018, 10:12:46 AM »
I am currently working on a way to import inventor ipt files into Autocad using C#. Im currently using AcadDocument.sendcommand, but this requires user interaction. Is there an alternative ways to interface with the import command?
Logged
WILL HATCH
Bull Frog
Re: Autocad Import command
Reply #1 on:
April 23, 2018, 02:30:14 AM »
Define requires user interaction?
Beyond setting filedia to 0? (I've never used the import .ipt feature)
Logged
hobbs1210
Mosquito
Reply #2 on:
April 23, 2018, 12:12:48 PM »
"Processing background job" dialog would pop up requiring the user to close it.
Logged
lamarn
Swamp Rat
Reply #3 on:
April 23, 2018, 05:38:04 PM »
This inventor import functionality will not work if your Inventor files come from a later version than the AutoCAD version.
It would be nice if user would get a notification of that. But it doesn't.
Logged
ChrisCarlson
Guest
Reply #4 on:
April 26, 2018, 08:31:04 AM »
You'll have to play with the hidden message settings of FixedProfile.
http://adndevblog.typepad.com/autocad/2013/07/disable-task-dialogs-programmatically.html
Logged
BIGAL
Swamp Rat
40 + years of using Autocad
Reply #5 on:
April 27, 2018, 03:10:26 AM »
In lisp a lot of the Command type can be run manually with some file dia and a - sign eg -line try it as -import.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
