Author Topic: Plotting in BricsCAD  (Read 4915 times)
GDF
« on: April 19, 2018, 08:38:38 AM »
I get the following to work in AutoCAD but not In BriscCAD...any ideals?
(command ".-plot" "Y" (getvar "ctab") "DWG To PDF.pc3" "Arch full bleed D (36.00 x 24.00 Inches)" "Inches"
    "Landscape" "N" "layout" "Fit" "" "Y" "PM (FULL SIZE).CTB" "Y" "Y" "N" "N" (getvar "ctab") "N" "Y")
BKT
Re: Plotting in BricsCAD
« Reply #1 on: April 19, 2018, 11:19:39 AM »
I'm not on the latest version, but I believe the PDF pc3 file for BricsCAD is called "Print As PDF.pc3" and there may be other differences. In earlier versions I see the ARCH D size labeled "ARCH D (36.00 x 24.00 Inches)" so you might want to go through the printer/plotter settings to verify.
GDF
« Reply #2 on: April 19, 2018, 12:41:45 PM »
Thanks, but I had already tried those options...no luck.
GDF
« Reply #3 on: April 19, 2018, 01:39:32 PM »
Got this to work:
(command ".-plot" "Y" (getvar "ctab") "DWG To PDF.pc3" "Arch D" "Inches" "Landscape" "N" "L" "F" "" "Y" "PM (FULL SIZE).CTB" "Y" "Y" "N" "N" "" "N" "Y")
GDF
« Reply #4 on: April 19, 2018, 02:10:55 PM »
Here is the code:
(defun PM:PDF  (LONAME)
  (setvar "ctab" LONAME)
  (if (= (getvar "cvport") 2)(command "pspace"))
    ((= "BRICSCAD" (strcase (getvar 'product)))
     (command ".-plot" "Y" LONAME "DWG To PDF.pc3" "Arch D" "I" "L" "N" "L" "F" "" "Y" "PM (FULL SIZE).CTB" "Y" "Y" "N" "N" (strcat (getvar "dwgprefix")(getvar "ctab")) "N" "Y"))
    ((/= "BRICSCAD" (strcase (getvar 'product)))
     (command ".-plot" "Y" LONAME "DWG To PDF.pc3" "Arch full bleed D (36.00 x 24.00 Inches)" "I" "L" "N" "L" "F" "" "Y" "PM (FULL SIZE).CTB" "Y" "Y" "N" "N" LONAME "N" "Y")))
  (princ))
