Author Topic: Check for AutoCAD or Bricscad  (Read 1781 times)
Atook
  • AKA Tim
« on: April 19, 2018, 01:47:46 AM »
I'm netloading a .NET dll, and need to change the file name depending on whether the user is running bricscad or autocad. I'm having trouble figuring out how to test that though.
What expressions can I use in place of isAutoCAD and isBricsCAD?
Code - Lisp: [Select]
  1. (if (isAutoCAD)
  2.   (setq dllName "App_AutoCAD.dll")
  3. )
  4.
  5. (if (isBricsCAD)
  6.   (setq dllName "App_Bricscad.dll")
  7. )
  8.
  9. ;; netload the dll
  10. (setq dllPath (strcat installFolder "/" dllName))
  11. (command "._NETLOAD" dllPath)
MatGrebe
  • Mosquito
Re: Check for AutoCAD or Bricscad
« Reply #1 on: April 19, 2018, 02:24:23 AM »
Something like:
(defun IsBrx( / )
   (if (str-pos (getvar "acadver") "BricsCAD")
      T
      Nil
Mathias
Atook
  • AKA Tim
« Reply #2 on: April 19, 2018, 02:52:09 AM »
Something like:
(defun IsBrx( / )
      T
      Nil
Mathias
Perfect. Thanks Mathias!
roy_043
  • BricsCAD 18
« Reply #3 on: April 19, 2018, 04:06:02 AM »
Another:
(= "BRICSCAD" (strcase (getvar 'product)))
« Reply #4 on: April 23, 2018, 09:59:29 AM »
Assuming the dll has the same name as the product, you could do something like this too:
  1. (if (findfile (setq dll (strcat installfolder "\\App_" (getvar 'product) ".dll")))
  2.   ;; NET LOW ADD
  3.   (command "_.NETLOAD" dll)
  4.   (print (strcase (strcat dll " not found!")))
  5. )
Atook
  • AKA Tim
« Reply #5 on: April 23, 2018, 04:43:51 PM »
Both also excellent, thank you.
