Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Why is this lisp count start point of 2 lines as one point?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Why is this lisp count start point of 2 lines as one point? (Read 1151 times)
HasanCAD
Swamp Rat
on:
April 18, 2018, 12:02:25 PM »
attached snapshop for the result no. 1 has 2 lines
The code
Code - Auto/Visual Lisp:
[Select]
defun
c:RVC
acad arc clyr doc gp gp1 i obj objs ortmd
p1 p1x p1y p2 p2x p2y p3 p4 p5 p5x p5y ptlist
sp spc tmp ts
vl-load-com
setq
doc
vla-get-ActiveDocument
setq
acad
vlax-get-Acad-Object
spc
if
zerop
vla-get-activespace
doc
if
vla-get-mspace
doc
:vlax-true
vla-get-modelspace
doc
vla-get-paperspace
doc
vla-get-modelspace
doc
setq
arc
500
setq
gp
getpoint
\n
Pick gathering porvcint"
setq
gp
trans
gp
1
0
setq
ts
getvar
'TEXTSIZE
setvar
'TEXTSIZE
250
setq
sp
getvar
'TEXTSIZE
setq
i
1
while
T
if
and
setq
p1
getpoint
\n
Pick first corner"
setq
p1
trans
p1
1
0
setq
ortmd
getvar
"orthomode"
setvar
"orthomode"
0
setq
p2
getcorner
p1
\n
Pick second corner"
setq
p2
trans
p2
1
0
setvar
"orthomode"
ortmd
progn
setq
clyr
getvar
"clayer"
vl-cmdf
"_.LAYER"
"MAKE"
"Defpoints"
setvar
"clayer"
clyr
setq
p1X
min
nth
0
p1
nth
0
p2
p1Y
min
nth
1
p1
nth
1
p2
p2X
max
nth
0
p1
nth
0
p2
p2Y
max
nth
1
p1
nth
1
p2
setq
p1
list
p1X p1Y
0
p2
list
p2X p2Y
0
p3
list
p2X p1Y
0
p4
list
p1X p2Y
0
ptlist
list
p1 p3 p2 p4
ptlist
apply
append
ptlist
setq
tmp
vlax
make
safearray
vlax-vbDouble
cons
0
length
ptlist
1
vlax-safearray-fill
tmp ptlist
setq
obj
vla-addPolyline
spc tmp
vla-put-closed
obj
:vlax-true
vl-cmdf
"_.Revcloud"
"A"
arc arc
entlast
"NO"
setq
obj
vlax
ename
vla-object
entlast
setq
objs
vla-put-layer
obj
"Defpoints"
setq
objs
vla-put-color
obj
256
if
0
nth
0
p1
setq
p5x
nth
0
p1
setq
p5x
nth
0
p2
if
0
nth
1
p1
setq
p5y
nth
1
p1
setq
p5y
nth
1
p4
setq
p5
kjk_nearest gp
list
p1 p2 p3 p4
setq
gp1
polar
gp
1.5
pi
setq
i
1+
i
sp
2
vl-cmdf
"_.LINE"
gp1 p5
setq
obj
vlax
ename
vla-object
entlast
setq
objs
vla-put-layer
obj
"Defpoints"
setq
objs
vla-put-color
obj
256
setq
objs
vla-put-linetype
obj
"Continuous"
setq
obj
vla-addtext
spc
strcat
itoa
1+
i
vlax-3D-point
gp1
sp
setq
objs
vla-put-layer
obj
"Defpoints"
setq
objs
vla-put-color
obj
256
setvar
'TEXTSIZE ts
defun
kjk_nearest
pt1 ptlist
tpt nearest
foreach
tpt ptlist
if
tpt
setq
nearest tpt
foreach
tpt ptlist
if
tpt
if
distance
tpt pt1
distance
pt1 nearest
setq
nearest tpt
nearest
Thanks in advance
Logged
Sorry for my English.
Donate to Theswamp
www.sergiwa.com
Global Moderator
Seagull
Re: Why is this lisp count start point of 2 lines as one point?
Reply #1 on:
April 18, 2018, 12:12:35 PM »
Without trying the lisp, Turn the osnaps off.
Logged
HasanCAD
Swamp Rat
Reply #2 on:
April 19, 2018, 03:09:52 AM »
Thanks CAB
Working perfect
Logged
Donate to Theswamp
www.sergiwa.com
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
