Author Topic: Get VideoCard Info.  (Read 1786 times)
Andrea
Get VideoCard Info.
« on: April 16, 2018, 02:32:04 PM »
Hi all,..
I'm trying to get video Card info...
with DOS prompt, I use this:
wmic path win32_VideoController get namewith it show: NVIDIA Quadro K1100M
In Lisp.. I use this:
  (setq wmi (vlax-create-object "WbemScripting.SWbemLocator"))
  (Setq objWMIService (vlax-invoke WMI 'CONNECTSERVER "." "root\\cimv2" nil nil nil nil nil nil))
  (setq colItems (vlax-invoke objWMIService 'EXECQUERY "Select * from Win32_VideoController"))
   (vlax-for item colItems (vlax-get item 'Name))
with it Show: Intel(R) HD Graphics 4600
So the question is,..
How can I get the correct value ? it seem that the Code do not get the correct Name VideoCard info from VidoController .
Any help will be appreciated.
Thank you.
Keep smile...
Andrea
Re: Get VideoCard Info.
« Reply #1 on: April 16, 2018, 02:34:43 PM »
got it..
sorry.. :)
     (if (setq GN (vlax-get item 'Name))
       (setq GNlist (append GNlist (list GN)))
Keep smile...
Grrr1337
« Reply #2 on: April 16, 2018, 03:52:21 PM »
<Daily news>: Heres something useful by Andrea.
Thanks for sharing! :)
(apply ''((a b c)(a b c))
vevo.bg
kruuger
« Reply #3 on: April 08, 2024, 05:04:21 AM »
hello,
Can we rework this code to get all displays (monitors) connected to our PC?
ribarm
  • Marko Ribar, architect
« Reply #4 on: April 08, 2024, 09:10:32 AM »
I think that WMI don't support Monitors or Displays... AFAIK it supports logical disks and graphics like Andrea posted...
Here are the codes :
(defun c:Graphic-Info ( / WMI objWMIService colItems GN GNlist r )
  (or (vl-catch-all-error-p (vl-catch-all-apply (function vlax-get-acad-object) nil)) (vl-load-com))
  (setq WMI (vlax-create-object "WbemScripting.SWbemLocator"))
  (setq objWMIService (vlax-invoke WMI 'CONNECTSERVER "." "root\\cimv2" nil nil nil nil nil nil))
  (vlax-release-object WMI)
  (vlax-release-object objWMIService)
  (vlax-release-object colItems)
  (setq r "")
  (foreach x GNlist
    (setq r (strcat r x " , "))
  (prompt (substr r 1 (- (strlen r) 3)))
(defun c:Disks-Info ( / WMI objWMIService colItems GN GNlist r )
  (setq colItems (vlax-invoke objWMIService 'EXECQUERY "Select * from Win32_LogicalDisk"))
  (setq r "")
  (foreach x GNlist
HTH.
M.R. on Youtube
ribarm
« Reply #5 on: April 08, 2024, 10:47:02 AM »
I was wrong ab WMI... Here is what you searched... It tells info ab Monitor through WMI...
(defun c:Monitor-Info ( / WMI objWMIService colItems GN GNlist r )
  (setq colItems (vlax-invoke objWMIService 'EXECQUERY "Select * from Win32_DesktopMonitor"))
  (setq r "")
  (foreach x GNlist
HTH.
M.R.
M.R. on Youtube
kruuger
« Reply #6 on: April 09, 2024, 02:07:18 AM »
  (setq r "")
  (foreach x GNlist
HTH.
M.R.
Hi Marko,
Thanks. Close, but returns only 1 display, when 3 are connected.
Any trick to get others?
kruuger
ribarm
« Reply #7 on: April 09, 2024, 06:23:53 AM »
I don't know, maybe all 3 are the same...
M.R. on Youtube
kruuger
« Reply #8 on: April 09, 2024, 03:41:28 PM »
dig more this issue. probably problem is that it is one monitor with 1 on each side, but at the end it is one big window desktop.
looks like return main screen info :(
