Author Topic: Save&Restore toolbars position  (Read 6325 times)
Marc'Antonio Alessi
  • Marco
« on: April 16, 2018, 01:00:42 PM »
Based on Lee Mac floatingtoolbarpositions I have written the functions below but I can not reposition correctly after moving...
(setq *AcadApp* (vlax-get-acad-object))
(defun ALE_Menu_ToolbarsSavePos ( / TmpLst OutLst LspOut FilPnt)
  (vlax-for MnuGrp (vla-get-MenuGroups *AcadApp*)
    (vlax-for VlaFor (vla-get-Toolbars MnuGrp)
      (setq TmpLst (cons (list (vla-get-name VlaFor) (vla-get-visible VlaFor) (vla-get-top  VlaFor) (vla-get-left VlaFor)) TmpLst))
    (setq OutLst (cons (cons (strcase (vla-get-name MnuGrp)) TmpLst) OutLst)  TmpLst nil)
    OutLst
      (setq FilPnt (open (setq LspOut "Z:\\Temp\\$Cfg_Menu.lsp") "w"))
      (princ "'" FilPnt) (princ (vl-prin1-to-string OutLst) FilPnt)
      (close FilPnt)
      (alert (strcat "Toolsbars position saved on File: " LspOut))
(defun ALE_Menu_ToolbarsRecoverPos ( / MnuGrp TlbInf MnuObj TbsObj TlbObj)
  (setq
    MnuGrp (vla-get-menugroups *AcadApp*)
    TlbInf (load "Z:\\Temp\\$Cfg_Menu.lsp")
  (foreach ForMnu TlbInf
      (cdr ForMnu)
      (setq MnuObj (ALE_Utl_GetItem MnuGrp (car ForMnu)))
      (setq TbsObj (vla-get-Toolbars MnuObj))
      (foreach ForElm (cdr ForMnu)
        (if (setq TlbObj (ALE_Utl_GetItem TbsObj (car ForElm)))
            (vla-put-visible TlbObj (cadr ForElm))
              (= :vlax-true (cadr ForElm))
              (vla-put-top TlbObj (caddr ForElm)) (vla-put-left TlbObj (cadddr ForElm))
(defun ALE_Utl_GetItem (VlaCol KeyNam / VlaObj)
  (vl-catch-all-apply
   '(lambda ( )
      (setq VlaObj (vla-item VlaCol KeyNam))
  VlaObj
(ALE_Menu_ToolbarsSavePos)
(ALE_Menu_ToolbarsRecoverPos)
Marc'Antonio Alessi
  • Marco
Re: Save&Restore toolbars position
« Reply #1 on: April 17, 2018, 04:53:24 AM »
Added DockStatus but do not works...
      (setq TmpLst (cons (list (vla-get-name VlaFor) (vla-get-visible VlaFor) (vla-get-top  VlaFor) (vla-get-left VlaFor) (vla-get-DockStatus VlaFor)) TmpLst))
    OutLst
      (close FilPnt)
  (setq
      (cdr ForMnu)
                (or (= (vla-get-DockStatus TlbObj) (nth 4 ForElm))  (vla-Dock TlbObj (nth 4 ForElm)))
  (vl-catch-all-apply
   '(lambda ( )
  VlaObj
Dlanor
« Reply #2 on: April 17, 2018, 03:37:57 PM »
The second menu in menugoups is "DBCONNECT" does not have a count property, therefore no (cdr) property list . Could this be the problem?
Marc'Antonio Alessi
  • Marco
« Reply #3 on: April 17, 2018, 03:48:55 PM »
In my version I have:
(defun Test ( / )
    (Print (vla-get-name MnuGrp))
"ACAD"
"CUSTOM"
"USER"
no "DBCONNECT"... I do not think this is the problem.
Dlanor
« Reply #4 on: April 17, 2018, 04:01:55 PM »
Must be version specific. When i run on my system (2012)  i get.
Command: (test)
"AUTOCADWS"
"DBCONNECT"
"ACAD"
"MODELDOC"
"RONSCUSTOM"
"EXPRESS"
"ACFUSION"
"CONTENTEXPLORER"
Not all of these have a toolbars property
Marc'Antonio Alessi
  • Marco
« Reply #5 on: April 17, 2018, 04:12:04 PM »
Ok, thanks... try this version (modify the path "Z:\\Temp\\$Cfg_Menu.lsp" of your choice):
; Only ACAD menu
(defun ALE_Menu_ToolbarsSavePos ( / TmpLst OutLst LspOut FilPnt MnuNam)
    (if (= (strcase (setq MnuNam (vla-get-name MnuGrp))) "ACAD")
    OutLst
      (close FilPnt)
Dlanor
« Reply #6 on: April 17, 2018, 05:27:27 PM »
Works OK for me, i get the expected list in the file.
Marc'Antonio Alessi
  • Marco
« Reply #7 on: April 18, 2018, 02:40:54 AM »
Yes, but if you move a Toolbar and run (ALE_Menu_ToolbarsRecoverPos) does the Toolbar return to its position?
For those wishing to try these functions, I say that they do not upset the Toolbars that have not been moved.
Perhaps it is better to go in the system registry read, save and then restore its values?
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\...\Profiles\ProfileA\Toolbars]
"ACAD.AC_SMOOTH_MESH"="hide float 200 200 1"
"ACAD.AC_SMOOTH_MESH_PRIMITIVES"="hide float 200 200 1"
"ACAD.TB_DIMENSION"="hide float 100 130 1"
"ACAD.TB_DRAW"="hide left 0 0"
"ACAD.TB_DRAWORDER"="hide right 0 1"
"ACAD.TB_INQUIRY"="hide float 100 170 1"
"ACAD.TB_INSERT"="hide float 100 190 1"
"ACAD.TB_LAYOUTS"="hide float 100 350 1"
"ACAD.TB_MODIFY"="hide right 0 0"
Dlanor
« Reply #8 on: April 18, 2018, 05:11:32 AM »
Oops i'll test and report back.
I'm always leery about writing to the registry, having had mishaps twice because i wasn't paying attention.  :uglystupid2:
Exporting/Importing the keys via shell using regedit would be another option, plenty of scripts out there but i've never tried it.
Also accessing the registry would depend on whether the user has named Profiles or just uses a default, and what if there is more that one profile?
acad-object -> preferences -> profiles -> activeprofile
should get you the "\ProfileA\" part for the active profile, but maybe exporting the entire tree from \Profiles\ would be the way to go.
Dlanor
« Reply #9 on: April 18, 2018, 05:46:50 AM »
Saves and restores as expected. :-)
Marc'Antonio Alessi
  • Marco
« Reply #10 on: April 18, 2018, 01:10:25 PM »
What do you mean? that if you move a Toolbar and run (ALE_Menu_ToolbarsRecoverPos) the Toolbar return to its saved position?
I do not have this behaviour...
Dlanor
« Reply #11 on: April 18, 2018, 04:29:21 PM »
Yes, i activated one hidden acad toolbar, and saved positions. I then moved the tool bar from centre screen to the left side and ran Restore. The toolbar was back in centre screen. Do you want me to test with more?
Marc'Antonio Alessi
  • Marco
« Reply #12 on: April 18, 2018, 05:25:04 PM »
Yes, please.  :-)
1) move the tool bar from centre screen to the left side NOT FLOAT (DOCKED) and ran Restore
2) save positions then move a DOCKED tool bar into the center and ran Restore
Thanks again. :embarrassed:
Dlanor
« Reply #13 on: April 18, 2018, 07:42:18 PM »
Ok i've run a few test using the previously stored, (this included the floating toolbar in centre screen). My Profile loaded normally, without the saved centre screen toolbar.
1. I took another invisible "ACAD" toolbar and docked it to the left hand side having unlocked the docked toolbars. Restoring the saved toolbar positions removed the docked toolbar and reinstated the previously saved centre screen floating toolbar.
2. When i moved a previously docked "ACAD" toolbar and made it floating it also restored it to its previous location.
3. I unlocked the docked toolbars moved an "ACAD" toolbar from docked to float then locked both floating and docked toolbar positions. It restored the toolbar to it's previous position.
This only works with "ACAD" toolbars, since your newest "save position" code only processes the "ACAD" toolbars and not "Express Tools" as i mistakenly moved one and it didn't restore.
From my end it's working within the scope of the functions in 2012. Will test later in 2009.
Dlanor
« Reply #14 on: April 19, 2018, 05:22:52 AM »
Same as above in 2009.
