Author Topic: eNullObjectID  (Read 3209 times)
WPerciful
eNullObjectID
« on: April 16, 2018, 11:42:18 AM »
I get an eNullObjectId error.  I thought I found the answer herehttp://www.theswamp.org/index.php?topic=47128.msg521607#msg521607, but I couldn't get it to work.  I also tried to lock the drawing but that didn't help.  The file it bombs on has locked viewports in it.  For some reason the code edits the viewport size and placement.  Bassed on the error message could it be the locked viewports are causing the error?
Original code:
    Public Function FindReplace(ldate As String, fn As String, strFind As List(Of String), strReplace As List(Of String))
        Dim ed As Autodesk.AutoCAD.EditorInput.Editor = Core.Application.DocumentManager.MdiActiveDocument.Editor,
            db As Database = New Database(False, True),
            dwgDir As String = IO.Path.GetDirectoryName(fn),
            dwgName As String = IO.Path.GetFileName(fn),
            dwgfullname As String = dwgDir & "\" & dwgName,
            log As New List(Of String)
        Using db
            Try 'FileOpenMode.OpenForReadAndAllShare
                db.ReadDwgFile(fn, FileOpenMode.OpenForReadAndAllShare, False, Nothing)
            Catch __unusedException1__ As System.Exception
                ed.WriteMessage(vbLf & "Unable to read drawing file.")
            End Try
            Dim lg As New List(Of String())(),
                txtClass = RXObject.GetClass(GetType(DBText)),
                mtxtClass = RXObject.GetClass(GetType(MText)),
                blkrefClass = RXObject.GetClass(GetType(BlockReference))
            Using tr = db.TransactionManager.StartTransaction
                Dim loDic As DBDictionary = CType(tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead, False), DBDictionary)
                For Each entry As DBDictionaryEntry In loDic
                    Dim layout = CType(tr.GetObject(entry.Value, OpenMode.ForRead), Layout)
                    Dim btr As BlockTableRecord = CType(tr.GetObject(layout.BlockTableRecordId, OpenMode.ForRead), BlockTableRecord)
                    For Each objID As ObjectId In btr
                        If objID.ObjectClass.IsDerivedFrom(blkrefClass) Then
                            Dim blkRef As BlockReference = CType(tr.GetObject(objID, OpenMode.ForRead), BlockReference),
                                acblkName As String = blkRef.Name, ' Error is here
                                nbtr As BlockTableRecord = CType(tr.GetObject(blkRef.BlockTableRecord, OpenMode.ForRead), BlockTableRecord),
                                attCol As AttributeCollection = blkRef.AttributeCollection
                            If attCol IsNot Nothing Then
                                For Each attId As ObjectId In attCol
                                    Dim att As AttributeReference = CType(tr.GetObject(attId, OpenMode.ForWrite), AttributeReference),
                                            wksp As String = att.BlockName.ToString,
                                            hand As String = att.Handle.ToString,
                                            val As String = att.TextString,
                                            locX As String = att.Position.X.ToString,
                                            locY As String = att.Position.Y.ToString,
                                            locZ As String = att.Position.Z.ToString
                                    For i = 0 To strFind.Count - 1
                                        If val.Contains(strFind(i)) = True Then
                                            att.TextString = val.Replace(strFind(i), strReplace(i))
                                            att.RecordGraphicsModified(True)
                                            att.AdjustAlignment(db)
                                            log.Add(ldate & "," & att.TextString & "," & val & "," & "Attribute" & "," & dwgName & "," & wksp & "," & hand & "," & locX & "," & locY & "," & locZ)
                                            Dim wbd As Database = HostApplicationServices.WorkingDatabase
                                            HostApplicationServices.WorkingDatabase = db
                                        End If
                                    Next
                                Next
                            End If
                        End If
                    Next
                Next
                tr.Commit()
            End Using
            db.SaveAs(fn, DwgVersion.AC1027)
        End Using
        Return log
    End Function
Attempt to fix it:
        ' Using docLock As DocumentLock = Core.Application.DocumentManager.MdiActiveDocument.LockDocument()
        Using db
            End Try
                        If objID.ObjectClass.IsDerivedFrom(txtClass) Then
                            Dim txt As DBText = CType(tr.GetObject(objID, OpenMode.ForWrite), DBText),
                                wksp As String = txt.BlockName.ToString,
                                hand As String = txt.Handle.ToString,
                                val As String = txt.TextString,
                                locX As String = txt.Position.X.ToString,
                                locY As String = txt.Position.Y.ToString,
                                locZ As String = txt.Position.Z.ToString
                                If val.Contains(strFind(i)) Then
                                    txt.TextString = val.Replace(strFind(i), strReplace(i))
                                    txt.RecordGraphicsModified(True)
                                    log.Add(ldate & "," & txt.TextString & "," & val & "," & "DBText" & "," & dwgName & "," & wksp & "," & hand & "," & locX & "," & locY & "," & locZ)
                                    '   Need this code in order to insure that the attributes alignment remains
                                    txt.AdjustAlignment(db)
                                End If
                            Next
                        End If
                        If objID.ObjectClass.IsDerivedFrom(mtxtClass) Then
                            Dim mtxt As MText = CType(tr.GetObject(objID, OpenMode.ForWrite), MText),
                                       wksp As String = mtxt.BlockName.ToString,
                                       hand As String = mtxt.Handle.ToString,
                                       val As String = mtxt.Contents.ToString,
                                       locX As String = mtxt.Location.X.ToString,
                                       locY As String = mtxt.Location.Y.ToString,
                                       locZ As String = mtxt.Location.Z.ToString
                                    mtxt.Contents = val.Replace(strFind(i), strReplace(i))
                                    mtxt.RecordGraphicsModified(True)
                                    log.Add(ldate & "," & mtxt.Contents & "," & val & "," & "MText" & "," & dwgName & "," & wksp & "," & hand & "," & locX & "," & locY & "," & locZ)
                                End If
                            Next
                        End If
                            If blkRef IsNot Nothing Then
                                Dim nbtr As BlockTableRecord = CType(tr.GetObject(blkRef.BlockTableRecord, OpenMode.ForRead), BlockTableRecord), ' This is line 430
                                            End If
                                        Next
                                    Next
                                End If
                            End If
                        End If
                    Next
                Next
                tr.Commit()
            End Using
            'db.SaveAs(fn, Autodesk.AutoCAD.DatabaseServices.DwgVersion.Current)
        End Using
        Return log
        ' End Using
    End Function
Error message:
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
Autodesk.AutoCAD.Runtime.Exception: eNullObjectId
   at Autodesk.AutoCAD.DatabaseServices.TransactionManager.GetObjectInternal(AcDbTransactionManager* pTM, ObjectId id, OpenMode mode, Boolean openErased, Boolean forceOpenOnLockedLayer)
   at Autodesk.AutoCAD.DatabaseServices.Transaction.GetObject(ObjectId id, OpenMode mode)
   at Joshua.frmPermianBasinWellSiteFacilityGenerator.FindReplace(String ldate, String fn, List`1 strFind, List`1 strReplace) in E:\Joshua\16APR18\Joshua\frmPermianBasinWellSiteFacilityGenerator.vb:line 430
   at Joshua.frmPermianBasinWellSiteFacilityGenerator.cmdGenerate_Click(Object sender, EventArgs e) in E:\Joshua\16APR18\Joshua\frmPermianBasinWellSiteFacilityGenerator.vb:line 231
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
WILL HATCH
Re: eNullObjectID
« Reply #1 on: April 23, 2018, 02:21:14 AM »
MGDDBG is your friend and will let you look at these problematic entities.
I'm curious why you're testing for rxclass isderivedfrom, what do you expect to be getting here?
I think you mean to grab the rxclass off the objectid and test if it's equal to that of a blockreference instead
