Author Topic: Dimension sum to text sum routine converting  (Read 7950 times)
danglar
  • Read My Li(s)(p)
Re: Dimension sum to text sum routine converting
« Reply #15 on: April 16, 2018, 01:40:18 AM »
I thinking about dimensions.. On this stage I decide I need linear dimensions only + numeric texts + block attributes (optional) without mtext. I understand, this is no so simple, but I do't want to lose a hope
Dlanor
« Reply #16 on: April 16, 2018, 10:40:34 AM »
OK, I'll try to finish it tomorrow.
Dlanor
« Reply #17 on: April 17, 2018, 06:03:02 AM »
Attached is lisp. Please read the comments at the top of the file.
danglar
  • Read My Li(s)(p)
« Reply #18 on: April 17, 2018, 07:04:30 AM »
First of all thank you Dlanor for an excellent routine!
After my checking a conclusion is: all working properly among dimensions texts and block attributes
Remain only one question. Is it possible to highlight selected entities like in ssget function?
In common case will be better to use ssget function with window selecting. In your case we need to select needful objects one by one and if the object not highlighted difficult to know if it already selected...
Dlanor
« Reply #19 on: April 17, 2018, 08:09:53 AM »
Off the top of my head, No. You can highlight the text and dimensions, but not the block attribute, only the block itself without losing the other highlighted objects.
danglar
  • Read My Li(s)(p)
« Reply #20 on: April 17, 2018, 08:18:24 AM »
well. how to highlight the texts and dimensions?
Can you improve it in the routine?
Dlanor
« Reply #22 on: April 17, 2018, 08:34:38 AM »
Is that highlight the text and dims and not the blocks, or highlight everything selected?
danglar
  • Read My Li(s)(p)
« Reply #23 on: April 17, 2018, 08:44:42 AM »
I thinking about it.. It seems to me better to highlight everything selected.. better to manage selected objects and divide it from not selected objects
Dlanor
« Reply #24 on: April 17, 2018, 11:09:45 AM »
Attached is update lisp to highlight selected dims, text and the parent block of the selected attribute. The highlighted items are reset as the lisp exits.
« Reply #25 on: April 17, 2018, 01:44:17 PM »
Dlanor,
FYI:  You can use the 'redraw' function to highlight entities (works with attributes).  Click on the 'redraw' name in the code below to see the man page for it.
  1. (setq sel (nentsel))
  2. (redraw (car sel) 3)
  3. ; (redraw (car sel) 4) ; this will un-highlight
  4.
danglar
  • Read My Li(s)(p)
« Reply #26 on: April 17, 2018, 03:15:08 PM »
thank you very match Dlanor. your help is very appreciated by me especially on your birthday.
 all works like a charm and like I need.
you are the real MASTER :smitten:
Dlanor
« Reply #27 on: April 17, 2018, 03:49:43 PM »
In truth, i'm barely a youngling compared to most here.   :embarrassed:
Dlanor
« Reply #28 on: April 17, 2018, 05:37:51 PM »
Dlanor,
  4.
Sorry but I missed this earlier. At the moment i'm highlighting the Block but this works much better. Many Thanks  :yay!:
