Author Topic: Dimension sum to text sum routine converting  (Read 7947 times)
danglar
  • Read My Li(s)(p)
« on: April 11, 2018, 10:01:31 AM »
The first attached routine (Dimension Sum Export - DS.lsp) can sum dimension values and export it to text file in format A+B+C+.. = Sum
I need to convert/add to this routine option for numeric text sum and numeric block attributes (optional) and export it in a same format.
Second attached routine (add.lsp) can do this process but have a different export format
Is it possible to combine these routines?
Any help will be very appreciated
« Last Edit: April 11, 2018, 10:04:36 AM by danglar »
Dlanor
Re: Dimension sum to text sum routine converting
« Reply #1 on: April 11, 2018, 08:41:06 PM »
Quick and dirty. No check if selected text is a number.
  1. ; Select Text Numbers. A right mouse button click (if set to enter) or press enter to end selection.
  2.
  3. (defun C:txt+ (/ c_doc ent ss t_lst xport_str fn file)
  4.         (prompt "\nPick Text numbers to add : ")
  5.                 ent (ssget '((0 . "TEXT")))
  6.                 ss (vla-get-activeselectionset c_doc)
  7.                 xport_str ""
  8.         )
  9.         (vlax-for obj ss
  10.                 (setq t_lst (cons (atof (vla-get-textstring obj)) t_lst))
  11.                 (if (= (strlen xport_str) 0)
  12.                         (setq xport_str (strcat xport_str (vla-get-textstring obj)))
  13.                         (setq xport_str (strcat xport_str " + " (vla-get-textstring obj)))
  14.                 )
  15.         )
  16.         (setq xport_str (strcat xport_str " = " (rtos (apply '+ t_lst) 2 3))
  17.                 ss nil
  18.                 fn (strcat (getvar "dwgprefix") "????? Export Report.txt");<<====ADJUST TO WHAT YOU REQUIRE
  19.                 file (open fn "a") ; append
  20.         )
  21.         (write-line "" file)
  22.         (princ xport_str file)
  23.         (close file)
  24.         (startapp "notepad.exe" fn)
  25. )
  26.
  27.
I cannot accomodate numeric block attributes as these require selecting individually using nentsel as opposed to the ssget where you can select by bulk if required.
danglar
  • Read My Li(s)(p)
« Reply #2 on: April 12, 2018, 04:54:47 AM »
Thank you Dlanor
Is it possible to include this solution as apart of main program?
Something like this: s (ssget (list '(0 . "DIMENSION,TEXT"))))
Dlanor
« Reply #3 on: April 12, 2018, 05:54:09 AM »
If i can find the time i'll give it a go.
danglar
  • Read My Li(s)(p)
« Reply #4 on: April 12, 2018, 05:55:08 AM »
thank you anyway..
Dlanor
« Reply #5 on: April 12, 2018, 11:08:08 AM »
OK, completed. Hope this is what you require. Once again there is NO checking that selected text items only contain numbers.
  1. ;; Select Dimensions or Text Numbers.
  2. ;; A right mouse button click (if set to enter) or press enter to end selection.
  3. ;; Be aware discrepancies may arise due to rounding required
  4.
  5. (defun c:ds (/ c_doc ent ss t_lst xport_str fn file txt_num)
  6.        (prompt "\nPick Text numbers to add : ")
  7.                 ent (ssget '((0 . "TEXT,DIMENSION")))
  8.                 ss (vla-get-activeselectionset c_doc)
  9.                 xport_str ""
  10.         )
  11.         (vlax-for obj ss
  12.                 (setq txt_num nil)
  13.                 (cond ( (wcmatch (vla-get-objectname obj) "*Dimension")
  14.                                                         (if (/= (vla-get-textoverride obj) "")
  15.        (setq txt_num (atof (vla-get-textoverride obj)))
  16.        (setq txt_num (vla-get-measurement obj))
  17.                                                         )
  18.                                         )
  19.                                         (       (wcmatch (vla-get-objectname obj) "*Text")
  20.                                                         (setq txt_num (atof (vla-get-textstring obj)))
  21.                                         )
  22.                 )
  23.                 (if txt_num
  24.                         (progn
  25.                                 (setq t_lst (cons txt_num t_lst))
  26.                                 (if (= (strlen xport_str) 0)
  27.                                         (setq xport_str (strcat xport_str (rtos txt_num 2 1)))
  28.                                         (setq xport_str (strcat xport_str "+" (rtos txt_num 2 1)))
  29.                                 )
  30.                         )
  31.                 )
  32.         )
  33.         (setq xport_str (strcat xport_str "=" (rtos (apply '+ t_lst) 2 1))
  34.                  ss nil
  35.                  fn (strcat (getvar "dwgprefix") "Dimension Export Report.txt")
  36.                  file (open fn "a"); append
  37.         )
  38.         (write-line "" file)
  39.         (princ xport_str file)
  40.         (close file)
  41.         (startapp "notepad.exe" fn)
  42.         (princ)
  43. )
  44. ;(c:ds)
  45.
  46.
« Reply #6 on: April 12, 2018, 11:15:16 AM »
Thank you Dlanor
I would like to see you write some code on your own one day.
danglar
  • Read My Li(s)(p)
« Reply #7 on: April 13, 2018, 05:44:37 AM »
Thank you Dlanor.
I very appriciate your help.
I would like to see it too Mark. I spend a lot of time to write my own codes and I have some progress in my tryings, but I achived sucsess only in modifications of existing codes. Whats why I'm here in a swamp.. to learn from guru's how to do it well
Dlanor
« Reply #8 on: April 13, 2018, 03:04:23 PM »
Thank you Dlanor.
Not a problem. I still can't figure out how to get attributes in there. I can do text and attributes but it would mean losing the dimensions.  :nerdyembarassed:
« Reply #9 on: April 14, 2018, 02:36:16 PM »
Thank you Dlanor.
Just running through, but you can use the routine here to select attributes with window or crossing:  https://www.theswamp.org/index.php?topic=19886.msg488544#msg488544
Dlanor
« Reply #10 on: April 14, 2018, 06:20:06 PM »
Thanks, I'll check it out, although i've found another solution. Nentsel returns the parent entity as the last item in the list it returns. This allows me to sidestep parsing the formatted mtext string, and also allows any sub entity of the dimension to be selected to get to the parent entity and it's object.
Being brain dead,  I was looking for it in the entget data for the selected sub entity.  :idiot2:
Not what the OP needs, and it still needs a bit of tarting up and error checking
  1. (defun c:addtxts (/ c_doc ent e_len ss t_lst xport_str fn file txt_num)
  2.
  3.
  4.         (while (setq ent (nentsel "\nSelect Dimensions, Text Numbers or Attributes to Add : "))
  5.                 (if ent
  6.                         (progn
  7.                                 (setq e_len (length ent))
  8.                                 (if (> e_len 2)
  9.                                         (setq ent (car (nth (1- e_len) ent)))
  10.                                         (setq ent (car ent))
  11.                                 )
  12.                                 (setq obj (vlax-ename->vla-object ent))
  13.                                 (cond ( (or (= (vla-get-objectname obj) "AcDbAlignedDimension") (= (vla-get-objectname obj) "AcDbArcDimension"))
  14.        (setq txt_num (vla-get-measurement (vlax-ename->vla-object ent))
  15.        t_lst (cons txt_num t_lst)
  16.        )
  17.                                                         )
  18.                                                         (       (or (= (vla-get-objectname obj) "AcDbText") (= (vla-get-objectname obj) "AcDbAttribute"))
  19.        (setq m_txt (if (= (vla-get-objectname obj) "AcDbAttribute") "Attribute" "Text")
  20.        txt_num (rh:get_num (vla-get-textstring (vlax-ename->vla-object ent)))
  21.        )
  22.        (if (numberp txt_num)
  23.        (setq t_lst (cons txt_num t_lst))
  24.        (alert (strcat "Selected " m_txt " is NOT a number"))
  25.        )
  26.                                                         )
  27.                                                         (t
  28.        (alert "Not a Distance Dimension, Text or Attribute")
  29.                                                         )
  30.                                 )
  31.                         )
  32.                 )
  33.         )
  34.         (alert (strcat "Total = " (rtos (apply '+ t_lst) 2 3)))
  35. )
  36.
danglar
  • Read My Li(s)(p)
« Reply #11 on: April 15, 2018, 05:00:42 AM »
Hi Dlanor.
I have some notes to published solution:
1. Solution needs internal function rh:get_num (this is not mentioned in published code)
2. Program works only with aligned or arc dimensions..
is it possible to publish get_num function and include all versions of dimensions in a routine?
Another question: Is it possible to include this common solution to main routine with output mentioned in my first post?
Dlanor
« Reply #12 on: April 15, 2018, 06:43:00 AM »
Hi Dlanor.
If you read my previous post again; i've stated that it is NOT what you (the OP) wants and that it is NOT the finished article. The missing function was my oversight and is below
  1. (defun rh:get_num ( txt )
  2.         (if (= (vl-string-trim ".0123456789" txt) "")
  3.                 (setq txt (atof txt))
  4.                 (setq txt '())
  5.         );end_if
  6. );end_defun
  7.
  8.
danglar
  • Read My Li(s)(p)
« Reply #13 on: April 15, 2018, 06:53:56 AM »
sorry for misunderstanding..  :uglystupid2:
what's about the rest of my questions?
Dlanor
« Reply #14 on: April 15, 2018, 02:41:27 PM »
There are 5 sorts of dimensions, linear, radial, angular, ordinate, and arc length. I can't see why you would need to include radial or ordinate, but look them up and decide which you want including.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/AutoCAD-Core/files/GUID-9A8AB1F2-4754-444C-B90D-CD3F2FC8A3E0-htm.html
If you do want any additions to those existing it will mean providing additional checks so that you cannot inadvertantly add linear and angular together etc.
