Author Topic: DWG to PDF.pc3  (Read 2719 times)
Pukenzz
DWG to PDF.pc3
« on: April 09, 2018, 08:45:46 AM »
I am using the DWG to PDF.pc3 printer option.
Is there a way to get it to…
•   Stop creating sheet views under the bookmark tab
•   Stop creating layers
•   Stop naming the page the same as my tab just name it 1, 2, 3, etc
•   Rotate the final print to landscape orientation
•   Set the navigation tab to page only
Thanks in advance
ChrisCarlson
Re: DWG to PDF.pc3
« Reply #1 on: April 09, 2018, 01:25:06 PM »
All but one of those are within the properties panel for the PC3 file.
BIGAL
  • 40 + years of using Autocad
Re: DWG to PDF.pc3
« Reply #2 on: April 09, 2018, 10:49:29 PM »
There are plenty of examples of using lisp and plot to pdf that will do exactly what you want. Here is an example http://www.cadtutor.net/forum/showthread.php?103522-Send-to-PDF
pendean
  • Mosquito
  • "I am not a number, I am a free man"
Re: DWG to PDF.pc3
« Reply #3 on: April 10, 2018, 01:10:02 PM »
What version of AutoCAD are you using?
Pukenzz
Re: DWG to PDF.pc3
« Reply #4 on: April 16, 2018, 04:28:21 PM »
Using Vanilla full version 2016 but getting ready to move to 2018
BIGAL
Re: DWG to PDF.pc3
« Reply #5 on: April 17, 2018, 06:45:58 AM »
Pukenzz 2019 is now out jump to that would be better if you can.
pendean
  • Mosquito
Re: DWG to PDF.pc3
« Reply #6 on: April 17, 2018, 08:47:07 AM »
In both versions explore how to set the PDF driver to do most of what you asked about as explained here https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoCAD-Core/files/GUID-B4A77E0A-76D2-4DEC-8E3E-0865DF550147-htm.html
