Author Topic: Alphabet character string only  (Read 12833 times)
XXL66
« on: April 08, 2018, 05:29:07 AM »
I think this should do the trick or is there another/easier method available with VL-string functions?
(defun AlphabetOnly ($ /)
  (while (and (wcmatch (substr $ 1 1) "@") $)
    (setq $ (substr $ 2))
Edit: should still check "" input...
« Last Edit: April 08, 2018, 05:34:28 AM by XXL66 »
Grrr1337
Re: Alphabet character string only
« Reply #1 on: April 08, 2018, 06:09:19 AM »
If I remember correctly Roy wrote some functions 'FullyAlphabetic' / 'FullyNumeric'.. and so on, but I'm unable to find that thread.
Anyway:
; _$ (StrNump "abcdefg") -> nil
; _$ (StrNump "abcdef8g") -> T
(defun StrNump ( s )
  (if (/= s "")
    (or
      (wcmatch (substr s 1 1) "#")
      (StrNump (substr s 2))
(apply ''((a b c)(a b c))
vevo.bg
Dlanor
« Reply #2 on: April 08, 2018, 06:10:27 AM »
Depends on your Alphabet  :thinking:
« Reply #3 on: April 08, 2018, 06:40:31 AM »
(defun alpha-p ( s ) (wcmatch s "~*[~A-Za-z]*"))
XXL66
« Reply #4 on: April 08, 2018, 07:36:20 AM »
 8-)
gile
  • Marseille, France
« Reply #5 on: April 08, 2018, 09:50:12 AM »
  1. (defun AlphaOnly (s)
  2.     '(lambda (x) (< 64 x 91))
  3.     (vl-string->list (strcase s))
  4.   )
  5. )
  6.
  7. (defun DigitOnly (s)
  8.     '(lambda (x) (< 64 x 91)))
  9.     (vl-string->list s)
  10.   )
  11. )
Dlanor
« Reply #6 on: April 08, 2018, 09:54:13 AM »
Neither account for a string with a space or spaces
« Reply #7 on: April 08, 2018, 10:16:02 AM »
Where did the OP state the requirement to permit spaces?
Dlanor
« Reply #8 on: April 08, 2018, 11:27:42 AM »
He didn't, i was merely pointing out that feeding in a string of only alphabet characters would return nil if there was a space, whereas Grr1337's wouldn't.
« Reply #9 on: April 08, 2018, 11:34:44 AM »
A space is not an alphabetic character.
As they should.
Dlanor
« Reply #10 on: April 08, 2018, 11:41:04 AM »
I agree, but it denotes no alphabet character, otherwiseitwouldmakereadingtextstringsmoredifficult.
« Reply #11 on: April 08, 2018, 11:45:03 AM »
completelyirrelevant
« Reply #12 on: April 08, 2018, 12:43:11 PM »
Back on track, want to say that:
(defun alpha-p (s) (wcmatch s "~*[~A-Za-z]*"))
And it's obvious companions like:
(defun digits-p (s) (wcmatch s "~*[~0-9]*"))
Are very elegant solutions. Nicely done Lee.
« Reply #13 on: April 09, 2018, 03:26:34 PM »
I don't see how it cannot be relevant.
Yes, when building a parser/etc. typically you often only use [A-Za-z] (or [:alpha:] in posix terms) and parse out other language structures separately (that's they way I've always done my parsing) but that doesn't make the request irrelevant.
If you want spaces just add it to the regex list.
  1. (defun alpha-p(s) (wcmatch s "~*[~A-Za-z],[ ]*"))
Command: (defun alpha-p (s) (wcmatch s "~*[~A-Za-z],[ ]*"))
ALPHA-P
Command: (alpha-p "test")
T
Command: (alpha-p "123")
nil
Command: (alpha-p "this is a big long string")
T
Command: (alpha-p "this is a big long string with numbers 123")
nil
« Reply #14 on: April 09, 2018, 03:44:35 PM »
Why stop there, you might as well pen goofy flavours of listp, minusp, numberp etc. while you’re at it.
