Author Topic: Alphabet character string only  (Read 13123 times)
roy_043
  • BricsCAD 18
Re: Alphabet character string only
« Reply #15 on: April 09, 2018, 04:58:47 PM »
@John:
You probably mean:
  1. (defun alpha-p (s) (wcmatch s "~*[~A-Za-z ]*"))
« Reply #16 on: April 09, 2018, 05:13:28 PM »
Why stop there, you might as well pen goofy flavours of listp, minusp, numberp etc. while you’re at it.
What (I'm confused)? ...No. But I don't see how the addition of spaces was all that big of a deal--as far as requests go--or that far out of possibilities -i.e. a user wanting to quickly check the string is of only alpha and spaces with a high level language (a language which doesn't treats strings as arrays).  I'm confused (that elevated quickly).
@John:
You probably mean:
Sure. That'll work.
EDIT: added a few words for clarity.
« Last Edit: April 09, 2018, 05:43:01 PM by John Kaul (Se7en) »
« Reply #17 on: April 09, 2018, 05:58:54 PM »
An isalpha predicate function that allows non alpha characters is illogical.
cadanalyst@gmail.com • http://cadanalyst.slack.com • http://linkedin.com/in/cadanalyst
« Reply #18 on: April 09, 2018, 06:05:33 PM »
Wait, what!? Ha! If that's all, then much of the autolisp (and all programming lanuage) community is in trouble. I've seen whole solutions developed with functions named after vowels. I've seen countless functions names "foo" and "bar". ...change the name.
VovKa
  • Ukraine
« Reply #19 on: April 09, 2018, 07:14:42 PM »
yep, and it returns nil for the Alpha itself :)
(alpha-p "α")
« Reply #20 on: April 09, 2018, 09:16:46 PM »
(alpha-p "α")
 :uglystupid2: appropriate
XXL66
« Reply #21 on: April 10, 2018, 05:40:04 AM »
@John:
You probably mean:
Was that yours Roy? Very neat work!
roy_043
  • BricsCAD 18
« Reply #22 on: April 10, 2018, 06:50:19 AM »
@John:
You probably mean:
I just added a space to Lee's suggestion in response to John's attempt (which does not work properly).
Marc'Antonio Alessi
  • Marco
« Reply #23 on: April 10, 2018, 07:44:47 AM »
(alpha-p "α")
Excuse my ignorance, why?
Comando: (ascii "α") 92
Comando: (chr 92)   "\\"
Comando: (ascii "\\") 92
scottcd
« Reply #24 on: April 10, 2018, 08:24:42 AM »
(ascii "a") returns 97 in both Autocad 2018 and BricsCAD 18.2
AutoCAD Dos R9 - 2018 and BricCAD 18.2
« Reply #25 on: April 10, 2018, 08:25:21 AM »
@John:
You probably mean:
Hey!? what do you mean my addition doesn't work properly. Does so. Does so! Well, at least it should (but I guess it depends on the regex guts autodesk used but it should). I only had AutoCAD 2016 installed (and before the other day, I didn't even know I had AutoCAD installed on this machine).
Command: (defun a (s) (wcmatch s "~*[~A-Za-z ]*"))
A
Command: (a "test")
T
Command: (a "a")
T
Command: (a ".")
nil
Command: (defun b (s) (wcmatch s "~*[~A-Za-z],[ ]*"))
B
Command: (b "test")
T
Command: (b "a")
T
Command: (b ".")
nil
That's odd. If I'm not mistaken, Portuguese is your natural language and Portuguese uses cp850 or cp860 but only the extended char set in those differs from the std char set.
https://www.ascii-codes.com/cp860.html
Weird! If you figure that one out, let me know (you have peeked my interest).
« Reply #26 on: April 10, 2018, 08:28:06 AM »
  1. _$ (a "1a")
  2. nil
  3. _$ (b "1a")
  4. T
« Reply #27 on: April 10, 2018, 08:38:14 AM »
  1. _$ (a "1a")
  2. nil
  3. _$ (b "1a")
  4. T
Ah! Got it. Thanks, Lee Mack. I apologize, roy_043. I removed your name from my list.
Marc'Antonio Alessi
  • Marco
« Reply #28 on: April 10, 2018, 08:56:54 AM »
I have: Code page 850 (Latin-1 - Western European languages)
Comando: SYSCODEPAGE    = "ANSI_1252" (solo lettura)
Comando: DWGCODEPAGE  = "ANSI_1252" (solo lettura)
