Author Topic: Sreenmenu  (Read 2814 times)
GDF
Sreenmenu
« on: April 05, 2018, 08:23:32 AM »
Don't laugh...
;;Command: REDEFINE
;;Enter command name: screenmenu
;;(setvar "SCREENMENU" 1)
Does anyone have an example of adding a screen menu form another loaded partial submenu into the Acad menu?
BIGAL
  • 40 + years of using Autocad
Re: Sreenmenu
« Reply #2 on: April 06, 2018, 08:21:33 PM »
Its been a while but I like them, you can have sub screens using the option to call another screen [0-100] -> screen 0-100
**WALLW
[AutoCAD]^C^C^P$S=X $S=S
[SELECT]
[WALL]
[WIDTH]
[  50mm]50
[  60mm]60
[  70mm]70
[  80mm]80
[  90mm]90
[ 100mm]100
[ 110mm]110
[ 150mm]150
[ 200mm]200
[ 230mm]230
[ 250mm]250
[ 300mm]300
In your menu or lisp when asked for say getreal do this first.
(menucmd "s=wallw")
« Last Edit: April 06, 2018, 08:50:50 PM by BIGAL »
GDF
Re: Sreenmenu
« Reply #3 on: April 07, 2018, 02:28:06 PM »
I am looking for an example on how to create a screen menu. I always edit my legacy mnu files to be recompiled by the cui editor.
***SCREEN
**PMdesign
...and so on
BIGAL
Re: Sreenmenu
« Reply #4 on: April 09, 2018, 10:55:09 PM »
Did I not post what you want ? Its from a working menu containing multiple screen menu's. You should be able to load a partial menu that you have created, I have one at home will try to post
« Last Edit: April 09, 2018, 11:01:26 PM by BIGAL »
