Author Topic: Floating Toolbar Locations  (Read 3365 times)
Dave M
« on: April 02, 2018, 12:20:54 PM »
I created a workspace for myself with a few floating toolbars.  If I switch to another workspace and then switch back my toolbars are not where I placed them.
Does anyone have, or know of, a routine that would save the positions of the floating toolbars so I can place them back where I want them easily?
Thanks for any possible help
Civil 3D 2018 - Microstation SS4 - Windows 10 - Dropbox
dgorsman
Re: Floating Toolbar Locations
« Reply #1 on: April 02, 2018, 01:00:41 PM »
There is a setting which controls auto-saving your workspace.  When this is off, you need to manually save any changes you make e.g. moved/hidden/shown toolbars.  When it's on any changes are saved as you make them; however, this counts *any* changes including some situations where you don't want it saved e.g. a partially loaded CUIx cannot be found when starting the program, or temporarily hiding something because you don't need it right now.
I usually recommend keeping the setting as off, and deliberately saving changes rather than letting the program decide "Hey that's new so we'll keep going with that...".
Check out the WSAUTOSAVE system variable and the WSSAVE command.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
« Reply #2 on: April 02, 2018, 01:03:33 PM »
Agree with dgorsman, but the following is a quick function to obtain the positions of all floating toolbars for a given menugroup:
  1. (defun floatingtoolbarpositions ( mgp / mnu rtn )
  2.     (if
  3.         (not
  4.             (vl-catch-all-error-p
  5.                 (setq mnu
  6.                     (vl-catch-all-apply 'vla-item
  7.                         (list (vla-get-menugroups (vlax-get-acad-object)) mgp)
  8.                     )
  9.                 )
  10.             )
  11.         )
  12.             (function
  13.                 (lambda ( tbr )
  14.                     (if (and (= :vlax-true (vla-get-visible tbr)) (= actoolbarfloating (vla-get-dockstatus tbr)))
  15.                         (setq rtn
  16.                             (cons
  17.                                 (list
  18.                                     (vla-get-name tbr)
  19.                                     (vla-get-top  tbr)
  20.                                     (vla-get-left tbr)
  21.                                 )
  22.                                 rtn
  23.                             )
  24.                         )
  25.                     )
  26.                 )
  27.             )
  28.         )
  29.     )
  30.     (reverse rtn)
  31. )
e.g.:
  1. (floatingtoolbarpositions "ACAD")
Dave M
« Reply #3 on: April 02, 2018, 02:04:30 PM »
dgorsman - I always keep the WSAUTOSAVE setting at zero; thanks for the reply.
Lee - thanks for the code. Works perfect as usual.  Is it normal for the "Y" value to be listed first?
I wish I knew how to code.  I would create something that would let me write the coordinates of the toolbars to a text file that I could import if I wanted at a later date.
I should have mentioned that I am using Civil 3D.  I don't think it matters, but I can't understand why they don't come back to their original positions.
Thanks again.
GDF
« Reply #4 on: April 02, 2018, 03:09:15 PM »
You can always hard code them into a position.
First show them, then position them as in code below:
  (command "toolbar" "ALL" "hide")
  (command "toolbar" "acad.TB_STANDARD" "show")
  (command "toolbar" "acad.TB_LAYER" "show")
  (command "toolbar" "arch.arch_program" "show")
  (command "toolbar" "arch.arch_sset" "show")
  (command "toolbar" "arch.arch_toolpalette" "show")
  (command "toolbar" "acad.TB_STANDARD" "top" "0,0")
  (command "toolbar" "acad.TB_LAYER" "top" "515,0")
  (command "toolbar" "arch.arch_program" "top" "825,0")
  (command "toolbar" "arch.arch_sset" "top" "900,0")
  (command "toolbar" "arch.arch_toolpalette" "top" "950,0")
MSTG007
« Reply #5 on: April 02, 2018, 03:23:55 PM »
Thanks for sharing that. I had no idea you could do that.
Civil3D 2020
Marc'Antonio Alessi
  • Marco
« Reply #6 on: April 03, 2018, 01:22:58 PM »
e.g.:
I get nil...  where am I wrong?
Comando: (vla-get-toolbars (vla-Item (vla-get-menugroups (vlax-get-acad-object)) "Acad"))
#<VLA-OBJECT IAcadToolbars 0000000031adbcb8>
Comando: (floatingtoolbarpositions "Acad")
nil
Dlanor
« Reply #7 on: April 03, 2018, 01:43:24 PM »
nil
Does your workspace have any floating toolbars?  :idea:
Andrea
« Reply #8 on: April 03, 2018, 02:41:31 PM »
I've created my own config allowing to save toolbars layouts..
Keep smile...
Dave M
« Reply #9 on: April 03, 2018, 03:31:24 PM »
That looks like it works nicely!
Marc'Antonio Alessi
  • Marco
« Reply #10 on: April 03, 2018, 03:33:51 PM »
nil
You are right! I thought it would give me the position of all the toolbars. I apologize.
Edit:  modified line:   (if (= :vlax-true (vla-get-visible tbr)) ; (= actoolbarfloating (vla-get-dockstatus tbr))
Andrea
« Reply #11 on: April 03, 2018, 04:04:12 PM »
thanks,..I use it every days...with all users costum toolbars...
combined with another tool called MENULOADS wich allows to load and unload multiple menu in one shot..
and detect, edit, and save setting and associated MNL files..
« Last Edit: April 04, 2018, 03:50:41 PM by Andrea »
Keep smile...
Dave M
« Reply #12 on: June 22, 2018, 05:28:46 PM »
Is this something you would be willing to share?
