Author Topic: Reactors and SDI vs MDI  (Read 5569 times)
« on: June 01, 2005, 06:38:02 PM »
So I have been using code that Se7en thought was nice and clean
Quote from: Se7en
" (or jmm:plot_reactor
(setq jmm:plot_reactor (vlr-editor-reactor nil '((:vlr-commandEnded . jmm:cmdEnd))))) "
...Nice trick Jeff.
Thats "clean" I like that.
which is precisely why I started using it. I don't use reactors that much, however, so I never noticed this before. Using the code found in THIS thread, load it into a drawing while SDI=0. Open another drawing and type (vlr-reactors), you will get nil, which is what I expected.
Now start another instance of Acad, this time with SDI=1. Again load the code and verify that the reactor is working. Also, type !jmm:plot_reactor at the command line and the reactor will be listed. Now open another drawing....you should see errors as it is loading like this: "; error: no function definition: JMM:CMDEND" This is correct, as I haven 't loaded those defuns to this drawing. However, typing (vlr-reactors) now shows that a reactor is still present! The jmm:plot_reactor symbol is no longer valid, but the reactor is......how can this be in a lisp environment that normally does not carry from dwg to dwg? What can i do to avoid this? Also, since the reactor is already loaded, it allows another, identical, reactor to be loaded if I only use the check shown above. Any simple ways of dealing with this?
thanks,
Jeff
« Reply #1 on: June 01, 2005, 06:53:28 PM »
Huh?!
I havent messed with Reactors in a while, so im prolly not that good of use. BUT let me wrap my brain around that "loading thing" a bit.
« Reply #2 on: June 01, 2005, 06:58:40 PM »
Oh i got it! (Duh!?)
Its not the reactor or the "enviroment" its your 'Or' statment thats causing that.
Command: (or
           a
           (progn (princ "\n\"a\" isnt set.") (setq a 1)))
"a" isnt set.T
Command: !a
« Reply #3 on: June 01, 2005, 07:18:24 PM »
...Agian, I appologise Jeff; I'm sorry, you wanted to know how to deal with that? (I just saw your last statment as I was scrolling up.)
In your "or" statment you shouldnt execute a statment like that; you should check to see if the reactor exists. Something like this:
(or
  jmm:plot_reactor
     ((and
        (vlr-reactors :VLR-Editor-Reactor)
        (vlr-added-p jmm:plot_reactor)))
     ((setq jmm:plot_reactor
            (vlr-editor-reactor nil '((:vlr-commandEnded . jmm:cmdEnd)))))))
« Reply #4 on: June 01, 2005, 07:26:31 PM »
Quote from: Se7en
Um, nope. Let me try this again. After loading the reactor into the first opened drawing where SDI>0, I open a new drawing (which closes the first one) and I don't load ANY code, I get this:
Command: AECOPEN
Closing Autodesk Map project...
Opening an AutoCAD 2000 format file.
Regenerating model.
Command:
Command:
Initializing...
Command:
AutoCAD Express Tools Copyright © 2000 Autodesk, Inc.
AutoCAD menu utilities loaded.; error: no function definition: JMM:CMDEND
Command: (vlr-reactors)
((:VLR-Editor-Reactor #<VLR-Editor-Reactor>))
Command: !jmm:plot_reactor
nil
So that bit of code: (or sym (setq sym.....)) works great to keep it from reloading in the MDI arena, but when in SDI you get this when loading the first time in the second drawing:
((:VLR-Editor-Reactor #<VLR-Editor-Reactor> #<VLR-Editor-Reactor>)) and the event is triggered twice. Now if I open a third drawing, guess what....yep, load my handy doody reactor and it gets fired 3 times.....
Does that 'splain it a bit better?
« Reply #5 on: June 01, 2005, 07:37:01 PM »
OK, John,
Thanks for the kickstart...I think that this solves it, although I'm still not sure how the reactor gets carried from dwg to dwg....
    (setq jmm:plot_reactor (cadr (car (vlr-reactors :vlr-editor-reactor))))
And this works providing my plot reactor is the first of any other editor-reactors that might be loaded.....if there are others, I'm unsure of how to differntiate between them.
« Reply #6 on: June 01, 2005, 07:55:06 PM »
http://groups-beta.google.com/group/autodesk.autocad.customization/browse_thread/thread/4c42da98985709ba/00cf3ccee8d37743?q=vlr-object&rnum=6&hl=en#00cf3ccee8d37743
Jeff, Have you had a look at Eric Schneider's code from early days. ?
.. a couple previous to the one shown ..
(defun vlr-object .....
« Reply #7 on: June 01, 2005, 08:12:02 PM »
Thanks Kerry. No, I hadn't seen that code...and now that I have I think I hurt something, like one of my last remaining brain cells :)
I will continue some testing on this tomorrow.
« Reply #8 on: June 01, 2005, 08:15:34 PM »
.. and now that I have I think I hurt something,  ..
I know the feeling
You should see my 'too-hard' folder ..
:D
« Reply #9 on: June 02, 2005, 09:50:58 PM »
Oh well I tried. (Actualy, I prolly should have waited till I got home to answer. I made my comments as I was shutting down for the day and after I got the computer shut down I realised that my lisp statement was a bit ..."weird".)
But anyways, yeah I get cha now. That is kinda funny. The symbol is destroyed but the reactor is still there. huh?!
Good find Kerry, I'm gonna have to take a look at that some more. (Later though, im tired now.)
Yeah i got one of thos folders too *lol* ...I love those tough ones. They really get my brain going some times.
dubb
« Reply #10 on: July 14, 2005, 04:10:47 PM »
Quote from: Jeff_M
hows the brain cells doin man..? have we found a solution for this?
« Reply #11 on: July 14, 2005, 07:03:09 PM »
Actually I got busy and forgot about it.... :oops:
Amsterdammed
« Reply #12 on: July 16, 2005, 03:32:31 AM »
I might missunderstand something, but there is a function that makes reacors persistent; vlr-pers
(vlr-pers reactor) Makes a reactor persistent
(vlr-pers-list [reactor]) Returns a list of persistent reactors in the current drawing
(vlr-pers-p reactor) Determines whether or not a reactor is persistent
(vlr-pers-release reactor) Makes a reactor transient
doesn't that do what you want?
Bernd
Columbia
« Reply #13 on: July 18, 2005, 11:27:26 AM »
I don't really know why the reactor is remaining persistent in a SDI=1 mode, but the following tips might help with some of the problems.
First...how to distinguish which reactor is yours in a reactor command stack.
In each reactor creation method there is an argument that is normally left 'nil' by a lot of coders, because they don't know what to do with it.  Well here's a nifty idea.  The first argument in the (vlr-editor-reactor) function is a data argument.  In the Acad help files it says to use this argument to attach any LISP code to the argument.  This also means you can attach a string to the reactor object.  You can then READ that string using the (vlr-data) functions passing it an vlr-object.  Do you follow what I'm saying?  Here's an example:
(setq jmm_plot_reactor (vlr-Editor-Reactor "Plot Done" '((:vlr-commandEnded . jmm:cmdEnd))))
(vl-data vl-object)
"Plot Done"
Therefore you could loop through the editor reactor objects to find out if one of them is yours -- and pretty simply too.
(foreach reactObj (vlr-reactors :VLR-Editor-Reactor)
  (if (= (vlr-data reactObj) "Plot Done")
    (setq found reactObj)
Second...It is very, very, VERY important to scrub any non-persistent reactors from your drawing session upon exiting a drawing.  If you don't you get unexpected results, and *gasp* AutoCAD instability.  So here's a small snippet(s) that you will definitely want to add to your code -- the reactor creation one...
;; this code creates a drawing reactor that will allow AutoCAD to destroy
;; any and all reactors within a drawing when the drawing recieves a
;; beginclose event.  THIS IS VERY IMPORTANT
(if (not $$_drawing-reactor_$$)
  (setq $$_drawing-reactor_$$
    (vlr-dwg-reactor nil '( (:vlr-beginclose . Remove-Reactors) ))
;; the following function scrubs all reactors from a drawing when called.
;; there are two arguments to this function.
(defun Remove-Reactors (calling_reactor_object data_list)
  (mapcar
    'vlr-remove-all
    '(:VLR-AcDb-reactor            :VLR-Editor-reactor
      :VLR-Linker-reactor           :VLR-Object-reactor
      :VLR-Command-Reactor    :VLR-DeepClone-Reactor
      :VLR-DocManager-Reactor :VLR-DWG-Reactor
      :VLR-DXF-Reactor             :VLR-Editor-reactor
      :VLR-Insert-Reactor          :VLR-Linker-Reactor
      :VLR-Lisp-Reactor             :VLR-Miscellaneous-Reactor
      :VLR-Mouse-Reactor          :VLR-Object-Reactor
      :VLR-SysVar-Reactor         :VLR-Toolbar-Reactor
      :VLR-Undo-Reactor            :VLR-Wblock-Reactor
      :VLR-Window-Reactor        :VLR-XREF-Reactor
  (setq jmm_plot_reactor nil)
Let me know if this helps out any.
