Author Topic: Change to Read Only after Opening Files  (Read 5686 times)
cmwade77
Re: Change to Read Only after Opening Files
« Reply #15 on: April 10, 2018, 12:01:18 PM »
Sorry, I meant to include a link.
Try this: https://www.peersoftware.com/peersync/
Any ideas on what the cost is?
rkmcswain
« Reply #16 on: April 10, 2018, 12:12:59 PM »
This is from probably 15 years ago, since it mentions Windows NT, XP, and 2000.
https://web.archive.org/web/20170521155714/https://www.dtsecurity.net/PeerSync_SNS_pricing_and_licensing.htm
So you could probably take that X4 or X5.
« Reply #17 on: April 10, 2018, 12:22:53 PM »
FWIW this does not sound like a problem suited for lisp.
cmwade77
« Reply #18 on: April 10, 2018, 12:25:58 PM »
I don't necessarily disagree, but this is first I have had anyone be able to suggest any software that might just do the trick, so I was going with what I knew.
« Reply #19 on: April 10, 2018, 12:35:02 PM »
How are your servers syncing files now?
cmwade77
« Reply #20 on: April 10, 2018, 12:46:01 PM »
We are using a program called ResilioSync, but it doesn't sync file locks.
« Reply #21 on: April 10, 2018, 12:49:55 PM »
If you're using two Windows servers within a domain, you can use builtin DFS.
cmwade77
« Reply #22 on: April 10, 2018, 01:02:13 PM »
Unfortunately, they are on different domains and one is in Oregon and one is in Singapore. Although they are connected by VPN.
Crank
« Reply #23 on: April 12, 2018, 05:02:13 PM »
I don't know exactly what you want to accomplish. But if the file is open on the other server, can't you just undefine/redefine the SAVE-commands?
cmwade77
« Reply #24 on: April 12, 2018, 05:09:03 PM »
That is something to consider.
