Author Topic: Feature Lines - Label Elevation Points  (Read 5839 times)
Rod
« on: March 26, 2018, 05:06:10 PM »
I have feature line label style that shows the Elevation of the Feature line ("General Segment Start Z") and the elevation of the surface (Reference Text - Surface Elevation)
I then add this label using multiple segments and drag the label grip to the start of the segment for each segment
I then add a similar style with  ("General Segment End Z") to the last segment and drag the grip it to the end of the line.
At this risk of opening up to a Autocad Civil whinge
Is there a better way to do this?
TIA, Rod.
"All models are wrong, some models are useful" - George Box
Rod
Re: Feature Lines - Label Elevation Points
« Reply #1 on: March 26, 2018, 05:17:36 PM »
My Current Workflow
Painful for lots of or long feature lines
« Reply #2 on: March 26, 2018, 07:40:05 PM »
Rod, when using the ReferenceText component for the Surface elevation, I'm not aware of any other workflow than what you are using. It may be possible to write a small program to do the moving of the grip automatically once the label is placed, but even that may prove to be tricky.
Rod
« Reply #3 on: March 26, 2018, 09:57:13 PM »
OK thanks Jeff
« Reply #4 on: March 27, 2018, 10:14:28 AM »
OR
Add those featurelines to a surface...any surface
then use surface spot elevation labels....they'll be right (correct) elevation anywhere
on the surface or the feature line....
MMccall402
« Reply #5 on: March 28, 2018, 02:44:07 PM »
I'm not understanding the need to drag these labels.  Why not just anchor the Start Z to the 'start' of the segment and the End Z to the 'end' of the segment.
« Reply #6 on: March 28, 2018, 04:57:00 PM »
MMccall402, the Surface Reference Text Component gets the elevation at the location of the label grip, not the anchor point. When you label multiple segments, the grip is always placed at the midpoint of the segment. To get the surface elevation at either the  start or end, you must drag the grip to that location.
mjfarrell, the OP has 2 text components...1 for the elevation of teh F/L and the other for the surface elevation. This way they can compare the 2 elevations quickly.
Rod
« Reply #7 on: March 28, 2018, 05:17:48 PM »
I probably will use a surface spot level instead.
Showing the design surface and the natural surface spot levels (I think that is the same as what MJ is suggesting)
Now just to find a way to reactor their positions off a design feature line
« Last Edit: March 28, 2018, 06:37:26 PM by Rod »
« Reply #8 on: March 28, 2018, 05:33:10 PM »
My suggestion doesn't stop one from using a reference text component or three....
