Author Topic: Textbox - unwanted behavior? Box text by Lee Mac as example  (Read 3120 times)
ziele_o2k
« on: March 18, 2018, 10:17:56 AM »
I have big problem with autolisp function textbox.
If string in text consists of some specific characters (for exmple: only dashes), then teturned coordinates by textbox function are wrong.
As example you can use LeeMac's Box Text routine, example in attached screen.
We found solution for spaces problem but now I have no idea what to do with that...
rkmcswain
Re: Textbox - unwanted behavior? Box text by Lee Mac as example
« Reply #1 on: March 19, 2018, 08:50:51 AM »
What version of AutoCAD are you using?
It works as expect in 2017 here.
ribarm
  • Marko Ribar, architect
« Reply #2 on: March 19, 2018, 09:15:43 AM »
Probably A2014...
M.R. on Youtube
« Reply #3 on: March 19, 2018, 09:26:15 AM »
Quick test here and it's dependent on the textstyle .. these TTF don't show up correctly.
rkmcswain
« Reply #4 on: March 19, 2018, 09:28:16 AM »
@ronjonp - what version?  My image in post #2 contains a TTF font, where it does work. (2017)
« Reply #5 on: March 19, 2018, 09:31:36 AM »
AutoCAD 2018
rkmcswain
« Reply #6 on: March 19, 2018, 09:46:21 AM »
Interesting.
I just did this in 2018.
« Reply #7 on: March 19, 2018, 10:10:26 AM »
Maybe try it on the attached drawing.
rkmcswain
« Reply #8 on: March 19, 2018, 10:46:29 AM »
Still works okay (yellow boxes are mine). Perhaps we are not conducting the same tests?
I'm running the Box Text routine from LeeMac as stated in the original post (with default 0.35 offset factor).
« Reply #9 on: March 19, 2018, 10:57:57 AM »
Yup ... I'm using THIS .. with an offset factor of 0.
ribarm
« Reply #10 on: March 19, 2018, 11:03:13 AM »
That explains things...
I was using :
(defun c:frame ( / enx pl )
  (setq enx (entget (car (entsel "\nPick text..."))))
  (setq pl (mapcar '(lambda ( x ) (mapcar '+ (cdr (assoc 10 enx)) x)) (textbox enx)))
  (vl-cmdf "_.RECTANGLE" "_non" (car pl) "_non" (cadr pl))
« Last Edit: March 19, 2018, 11:06:58 AM by ribarm »
M.R. on Youtube
ziele_o2k
« Reply #11 on: March 19, 2018, 11:31:17 AM »
I forgot to check topic since morning and so many replies.
I'm using autocad 2018 and zwcad 2015, same wrong results with Lee Mac Box Text (TTF times new roman as font).
rkmcswain uses propably default offset as 0.35 not 0 as me and ronjonp
It seems to work fine with shx fonts
Edit:
I wrote to Autodesk, I will post their opinion.
« Last Edit: March 19, 2018, 11:35:11 AM by ziele_o2k »
ziele_o2k
« Reply #12 on: March 19, 2018, 11:53:54 AM »
I made some history review. TTF font support was introduced to autocad in AutoCAD Release 13 - 1994, AutoLISP was developed way before that - maybe here is problem?
But from other site, getboundingbox method also don't work (Visual-List introduced in 2000)  - use http://www.lee-mac.com/boundingbox.html and example calling function at bottom of site to check.
