Author Topic: Error Base.dcl not found  (Read 6264 times)
lamarn
« on: March 14, 2018, 06:25:24 PM »
I am getting errors on different computers where a Base.dcl error keeps popping up in every function that has a dcl (through a vlx file) I tried it with fresh profiles and different settings, nothing seems to work.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/DCL-errors-when-starting-AutoCAD-products.html
Any other suggestions than this one?
« Last Edit: March 14, 2018, 07:09:31 PM by lamarn »
Re: Error Base.dcl not found
« Reply #1 on: March 14, 2018, 07:50:14 PM »
verify that it is missing....then place a known good copy in the location it's supposed to be in.
lamarn
« Reply #2 on: March 15, 2018, 02:09:13 AM »
correction for the title. It is not missing, there is something wrong with it in relation with the vlx. I can't be checking all and every autocad install. It really seems there is something wrong with how the vlx ia made. When I rum the lsp/dcl separate the is not a problem.
« Reply #3 on: March 15, 2018, 09:56:45 AM »
I see someone else was having this issue....
they were directed to delete a particular registry key to clear it up:
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R17.1\ACAD-6018:409
It is version specific....so you would want to look under whatever version you are having the issue with.
dgorsman
« Reply #4 on: March 15, 2018, 01:06:50 PM »
Aaahhhh yeah.  No, don't do that.  That registry key points to the top-level of the AutoCAD settings for that user.  It will nuke *all* settings, profiles, everything, for that user.  Deleting that is the same as doing a re-install.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
« Reply #5 on: March 15, 2018, 01:20:49 PM »
Which might be exactly the cure for the problem...
« Reply #6 on: March 15, 2018, 01:41:16 PM »
« Reply #7 on: March 15, 2018, 01:47:47 PM »
Sometime....it is the right tool for the job....
sometimes it just feels good to use it.  ;)
lamarn
« Reply #8 on: March 15, 2018, 02:29:46 PM »
LOL 😁  would you believe today I got a brand new laptop after 4 years of good service.
First I need to get AutoCAD installed, than I will try again. Maybe start with just one lsp in one vlx to load.. To be continued
« Reply #9 on: March 15, 2018, 02:54:58 PM »
lamarn
« Reply #10 on: March 16, 2018, 06:41:38 AM »
.. 1 DCL..
lamarn
« Reply #11 on: March 19, 2018, 05:39:06 PM »
New Laptop, new installations, Same shit.
My tools installed on 2017 work but not on 2019 pre release on laptop 1 (new), and 2017 doesn't works but 2018 works on laptop 2 (old)
This can be found in acad.dce about when testing one of the dcl files.
I'm now looking into difference between base.dcl in the different versions, are there any differences?
====== DCL semantic audit of C:\Users\hala6\AppData\Local\Temp\$VL~~001.DCL ======
Error. Widget named "row" is undefined.
    Widgets of this type cannot have children.
Error. Widget named "column" is undefined.
Error. Widget named "boxed_row" is undefined.
Error. Widget named "boxed_column" is undefined.
« Last Edit: March 19, 2018, 05:47:46 PM by lamarn »
lamarn
« Reply #12 on: March 19, 2018, 05:51:33 PM »
previewing in *: no result, ..
; warning:cannot create tmp file for DCL: "C:/Program Files/Autodesk/AutoCAD Pi Release Candidate Beta/$vld$.dcl"
(other warning because apparently it needs administer rights..)
Previewing the same dcl in Vlide in 2018, it's ok
What am i doing 'illegal' ??
« Last Edit: March 20, 2018, 11:08:53 AM by lamarn »
dgorsman
« Reply #13 on: March 20, 2018, 10:40:14 AM »
Ermmm... BETA content should never be discussed in a public forum.  Check the date for the embargo being lifted.
Also, BETA installs have a tendency to bugger up some of the VLISP registry stuff - in the past I've had to do a full-reinstall of previous commercial releases (a repair install didn't work).
try {GreatPower;}
   finally
      {MasterBasics;}
« Reply #14 on: March 20, 2018, 11:12:28 AM »
NDAs, how do they work?
