Author Topic: Polyline arc end point misaligned  (Read 2812 times)
dubb
« on: March 13, 2018, 03:58:12 PM »
I'm not sure how to explain this.
I have a polyline with 2 arcs. The intersection of the two arcs are misaligned but technically they share the same end point. Is there some kind of variable that will fix this?
Re: Polyline arc end point misaligned
« Reply #1 on: March 13, 2018, 04:04:12 PM »
Regen?
dubb
« Reply #2 on: March 13, 2018, 04:21:17 PM »
Nope, that doesn't work.
Regen
Regenall
Nada.
dubb
« Reply #3 on: March 13, 2018, 04:23:29 PM »
See attached. 2018 cad file
« Reply #4 on: March 13, 2018, 04:53:35 PM »
they line up in my autocad....so it's a setting on yours....
circle arc smoothness setting in options?
sljohnson
« Reply #5 on: March 13, 2018, 04:55:56 PM »
Do you have multiple model space views? I notice the same thing when I have multiple model space views.
dubb
« Reply #6 on: March 13, 2018, 05:00:09 PM »
Ah...that fixed it.  :2funny:
I did try viewres and changed the arc/circle resolution to 1000. That didn't work.
« Reply #7 on: March 13, 2018, 06:09:49 PM »
Not sure if the multiple views is the issue...
I had multiple views, it did not appear disjointed for me.
« Reply #8 on: March 13, 2018, 08:29:23 PM »
It was disjointed here too until I made a single modelspace vport.
