Author Topic: ssget all LINES with Z elevation Not Zero  (Read 1955 times)
mailmaverick
« on: March 13, 2018, 09:59:15 AM »
How to ssget all LINES having Z coordinate of Startpoint or Endpoint or Both, not equal to zero.
One option is to select all lines and then iterate through all and remove those with Zero. But is there any direct method ?
Re: ssget all LINES with Z elevation Not Zero
« Reply #1 on: March 13, 2018, 10:58:32 AM »
Looks like there should be, as I can use a selection set in QuickSelect (3d polylines) Vertex Z <> not equal 0
And it finds only those objects....
I know that isn't much lisp help....
« Reply #2 on: March 13, 2018, 11:22:02 AM »
Here's a quick filter:
  1. (ssget "_X"
  2.        '((0 . "LINE")
  3.          (-4 . "<OR")
  4.          (-4 . "*,*,/=")
  5.          (10 0. 0. 0.)
  6.          (-4 . "*,*,/=")
  7.          (11 0. 0. 0.)
  8.          (-4 . "OR>")
  9.         )
  10. )
mailmaverick
« Reply #3 on: March 14, 2018, 02:50:08 AM »
Excellent Ron !!!!! Never knew that ssget could be used like this !!!!
HasanCAD
« Reply #4 on: March 14, 2018, 04:06:34 AM »
For more about ssget
http://lee-mac.com/ssget.html
« Reply #5 on: March 14, 2018, 09:56:15 AM »
Glad to help. :) HERE is some more material on filters.
