Author Topic: Creating a Layerstate Reactor  (Read 5019 times)
GDF
Re: Creating a Layerstate Reactor
« Reply #15 on: February 22, 2018, 07:04:40 PM »
OOPS
In BricsCAD I get this message:
Error: bad argument type <NIL> ; expected ENTITYNAME at [layerstate-restore]
; LISP execution error : inside <LAYERSTATE-CALLBACK> at [VLR-Miscellaneous-Reactor:vlr-layoutSwitched]
« Reply #16 on: February 23, 2018, 07:55:28 AM »
OOPS
This is due to BricsCAD's implementation of the layerstate-restore function - evidently the viewport argument is not considered optional in BricsCAD.
This will require a support request to BricsCAD to resolve.
roy_043
  • BricsCAD 18
« Reply #17 on: February 23, 2018, 08:38:21 AM »
... In the interim: use the BricsCAD vl-layerstates-restore function.
GDF
« Reply #18 on: February 23, 2018, 11:44:42 AM »
I posted this error to the BricsCAD forum.
GDF
« Reply #19 on: April 15, 2018, 11:13:59 AM »
Will the following work?
(setq program (substr (getvar "acadver") 6 (- (strlen (getvar "acadver")) 1)))
             ((= program "BricsCAD")(vl-layerstates-restore (getvar "ctab") 6 NIL 0))
             ((/= program "BricsCAD")(layerstate-restore las      nil 255)))
GDF
« Reply #20 on: April 15, 2018, 05:38:28 PM »
Made some other changes...it now works.
(if (= (getvar "program") "BRICSCAD")
« Reply #21 on: April 16, 2018, 09:54:07 AM »
Gary,
You could also do something like this:
  1. (if vl-layerstates-restore
  2.   (vl-layerstates-restore (getvar "ctab") 6 nil 0)
  3.   (layerstate-restore las nil 255)
  4. )
