Author Topic: Block not accepting changing X or Y scale  (Read 3062 times)
HasanCAD
« on: February 19, 2018, 06:38:38 AM »
This block comes crazy while I try to change the scale not accepting
The block should be Scale uniformily to accept any changes in scale
Thanks in advance
ChrisCarlson
Re: Block not accepting changing X or Y scale
« Reply #1 on: February 20, 2018, 03:02:12 PM »
Under block settings you have selected "no" for "Scale Uniformly", changing this to "yes" will cure your issues.
HasanCAD
« Reply #2 on: February 20, 2018, 04:53:58 PM »
Thanks for reply
As I mentioned I did that but
- The scale does not show the correct number
- I want to know why
« Reply #3 on: February 20, 2018, 06:00:50 PM »
there is some scaling occurring by a factor of 10.
I'm not sure why it's doing that either.
Did you make, create, or define this block yourself, or is it from others?
HasanCAD
« Reply #4 on: February 20, 2018, 11:37:04 PM »
It is from others
Dlanor
« Reply #5 on: February 21, 2018, 07:36:46 AM »
Could you send the block in 2010 format as i can't open it and have no way to convert it here.
HasanCAD
« Reply #6 on: February 21, 2018, 07:55:22 AM »
Attached
ChrisCarlson
« Reply #7 on: February 21, 2018, 08:57:08 AM »
Delete and reinsert the block, my hunch is that it's something to do with when it was imported into the drawing.
« Reply #8 on: February 21, 2018, 10:47:57 AM »
I would suggest you just recreate the block.
One it cleans up the mess
Two, it puts you in control of how it behaves.
Dlanor
« Reply #9 on: February 22, 2018, 06:22:57 PM »
The block has an associated extension dictionary attached to it. If you "vlax-dump-object" the object, it's HasExtensionDictionary property is set to  -1 (true). I don't know if this is somehow affecting the block.
There are also 4 very small unassociated hatches and a single line at the centre point of the block.
when i inserted another instance of the block into 2009 scaling it uniformly and then changing it's x,y & z scales it doesn't exhibit the same scaling problems as the initial block.
