Author Topic: Split String for list_box  (Read 3029 times)
Grrr1337
« on: February 18, 2018, 06:07:42 PM »
Hey guys,
I've got this scenario with a pretty long string that needed to be splitted at certain character(s) in order to be displayed correctly in a list_box tile.
My main uses multiple listboxes to display different paragraphs of info.
So In other words (code) :
  1. _$ (mapcar
  2.   '(lambda (x / tmp)
  3.     (setq tmp (SplitStringForLB x "The Quick Brown Fox Jumps Over The Lazy Dog."))
  4.     (cons x (cons (length tmp) tmp))
  5.   ); lambda
  6.   '(2 4 6 8 10 12 14 16 18 20 22 24 26)
  7. ); mapcar
  8. >>
  9. ( ; (car = argument) (cadr = amount of strings returned) (cdddr = the list of words which was returned)
  10.   (2 9 "The" "Quick" "Brown" "Fox" "Jumps" "Over" "The" "Lazy" "Dog.")
  11.   (4 6  "The Quick" "Brown" "Fox Jumps" "Over" "The Lazy" "Dog.") ; strlen of 4 or above is attempted to be splitted on the first following occurence of " " or "."
  12.   (6 5 "The Quick" "Brown Fox" "Jumps Over" "The Lazy" "Dog.") ; strlen of 6 or above is attempted to be splitted on the first following occurence of " " or "."
  13.   (8 5 "The Quick" "Brown Fox" "Jumps Over" "The Lazy" "Dog.")
  14.   (10 3 "The Quick Brown" "Fox Jumps Over" "The Lazy Dog.")
  15.   (12 3 "The Quick Brown" "Fox Jumps Over" "The Lazy Dog.")
  16.   (14 3 "The Quick Brown" "Fox Jumps Over" "The Lazy Dog.")
  17.   (16 3 "The Quick Brown Fox" "Jumps Over The Lazy" "Dog.")
  18.   (18 3 "The Quick Brown Fox" "Jumps Over The Lazy" "Dog.")
  19.   (20 2 "The Quick Brown Fox Jumps" "Over The Lazy Dog.")
  20.   (22 2 "The Quick Brown Fox Jumps" "Over The Lazy Dog.")
  21.   (24 2 "The Quick Brown Fox Jumps" "Over The Lazy Dog.")
  22.   (26 2 "The Quick Brown Fox Jumps Over" "The Lazy Dog.")
  23. )
Heres the function I used:
  1. (defun SplitStringForLB  (n s / a tmp r)
  2.   (setq tmp "")
  3.   (while (/= "" s)
  4.     (setq a (substr s 1 1))
  5.     (and (>= (strlen tmp) n) (member a '(" " ".")) (setq r (cons (strcat tmp (cond ((= a ".") (setq a "") ".")(""))) r)) (setq tmp ""))
  6.     (setq tmp ('((a b) (if (and (= "" a) (= " " b)) a (strcat a b))) tmp a))
  7.     (setq s (substr s 2))
  8.   ); while
  9.   (reverse ('((a b) (if (/= "" a) (cons a b) b)) tmp r))
  10. ); defun SplitStringForLB
  1. _$ (SplitStringForLB 6 "Abc de. Klmn op") >> ("Abc de." "Klmn op")
Just sharing.. and I think it would be interesting to see your attempts on this.  :tongue2:
« Last Edit: February 18, 2018, 07:01:07 PM by Grrr1337 »
(apply ''((a b c)(a b c))
vevo.bg
VovKa
  • Ukraine
Re: Split String for list_box
« Reply #1 on: February 18, 2018, 06:37:52 PM »
i think a 'period' should always stick to the previous word
« Last Edit: February 18, 2018, 06:41:06 PM by VovKa »
« Reply #2 on: February 18, 2018, 06:48:15 PM »
Not exactly the same but you may want to explore this very old routine.
https://www.theswamp.org/index.php?topic=1392.0
Grrr1337
« Reply #3 on: February 18, 2018, 07:06:38 PM »
Ah, thanks for pointing that out Vova - modified the code.
CAB, your link is broken (actually I was unable to access all the recent links you posted on the forum).
Anyway if you are refering to to your sparser, I'm aware of it. :)
vevo.bg
« Reply #4 on: February 18, 2018, 07:15:02 PM »
Not broken, just not valid https - change it to plain http and you should be fine: http://www.theswamp.org/index.php?topic=1392.0
Back on topic, here's an old one of mine, just looking at spaces.
Grrr1337
« Reply #5 on: February 19, 2018, 09:42:09 AM »
Sorry about my misunderstanding.
Well thats some hefty routine (I expected just some short and cute subfoo).
My main has just informative purpose, but the focus here is on this subfoo.
For sure I missed that!
Actually I've expected that you might have something like this, due your tremendous effort of writing lisp routines'n'subfunctions.  :-D
I did a small modification here, so if the following character was used ' • ' it would write as new-row and would tab(space) the next subrows [see pic] :
(defun SplitStringForLB  (n s / a tmp r flg)
  (setq tmp "")
  (while (/= "" s)
    (or
      (and (>= (strlen tmp) n) (member a '(" " ".")) (setq r (cons (strcat tmp (cond ((= a ".") (setq a "") ".")(""))) r)) (progn (if flg (setq tmp "   ") (setq tmp "")) t))
      (and (= a "\n") (progn (setq flg nil) t) (setq r (cons tmp r)) (setq tmp ""))
      (and (= a "•") (progn (setq flg t) t) (setq r (cons tmp r)) (setq tmp ""))
    ); or
  ); while
So the above yields:
_$ (SplitStringForLB 12 "• This would be the first thing • This is the second thing • This is the third thing")
("" "• This would"   "    be the first" "    thing "
  "• This is the"   "    second thing" "    "
  "• This is the"   "    third thing"
; Proper return would be (I think) :
( "• This would"   "    be the first" "    thing "
_$ (SplitStringForLB 12 "• This would be the first thing • This is the second thing\nthis is a new row • This is the third thing")
("" "• This would"
  "    be the first"
  "    thing "
  "• This is the"
  "    second thing"
  "\nthis is a new"
  "row "
  "• This is the"
  "    third thing"
Which I agree is 'buggy' so theres a way of improvement.
But still good to visualise in the list_box:
« Last Edit: February 19, 2018, 03:24:01 PM by Grrr1337 »
vevo.bg
