Author Topic: Wish List  (Read 5821 times)
GDF
Wish List
« on: February 16, 2018, 06:53:42 PM »
Starting my wish list:
(1) Block Editor like in AutoCAD
(2) Fixes to DCL controls: (works in AutoCAD)
      tabs in popup_list not working
          :popup_list {key="commands-list"; width=51.5; tabs="11"; multiple_select=false;}
      multiple_select=true in list_box not working
          :list_box {key="layer-list"; width=67; height=13; tabs = "18 22 33 40"; multiple_select=true;}
      tab_truncate=true in list_box works great
          :list_box {key="layer-list"; width=67; height=13; tabs = "18 22 33 40"; multiple_select=true; tab_truncate=true;}
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: Wish List
« Reply #1 on: February 16, 2018, 09:37:11 PM »
I'd suggest making a similar post on the BricsCAD Forum ... They are more likely able to do something about your wishes.
https://forum.bricsys.com/
Regards,
Called Kerry in my other life
I live at UTC + 13.00
Atook
  • AKA Tim
Re: Wish List
« Reply #2 on: February 17, 2018, 11:12:02 AM »
I'm hoping for improved mleaders, a non modal layer manager, and palettes with auto-hide.
And further down the road, a prettier UI.
roy_043
  • BricsCAD 18
Re: Wish List
« Reply #3 on: February 18, 2018, 07:03:28 AM »
@GDF:
Multiple_select works just fine. See the attached zip.
@Atook:
Are you aware of the _LayersPanelOpen command?
GDF
Re: Wish List
« Reply #4 on: February 18, 2018, 07:51:29 AM »
Thanks Roy
I'm going to have to look again at my code...
Gary
roy_043
  • BricsCAD 18
Re: Wish List
« Reply #5 on: February 18, 2018, 01:34:44 PM »
@GDF:
Tabs in a popup_list are also supported (zip attached).
It may be useful to have a look at the Developer Reference.
