Author Topic: Reorder Attribute Block Name  (Read 1860 times)
MSTG007
« on: February 16, 2018, 12:13:47 PM »
I have a Block that is "_TagCircleInvert". Problem is it is in A lot of dwgs. Looking for a method to reorder the block without going thru each drawing and opening the block editor. There are 2 attributes that need to be flipped.
thank you for any inputs...
Civil3D 2020
Dlanor
Re: Reorder Attribute Block Name
« Reply #1 on: February 16, 2018, 04:38:02 PM »
Define "Flipped"
MSTG007
« Reply #2 on: February 16, 2018, 05:04:15 PM »
I have 2 attributes in the block. The top one needs to go on the bottom likewise on the top. Like in ascending order.
Civil3D 2020
« Reply #3 on: February 16, 2018, 05:11:14 PM »
Top / Bottom as in the Y ordinate or as appears in the ATTEDIT dialog?
MSTG007
« Reply #4 on: February 16, 2018, 05:12:57 PM »
As seen in the att dialog box
Civil3D 2020
DEVITG
« Reply #5 on: February 17, 2018, 11:25:01 AM »
to avoid , so much doubts. Why not to show the true acad.dwg??
MSTG007
« Reply #7 on: February 19, 2018, 07:38:04 AM »
Sorry for taking so long to get back... Here is the block that will need to be re-ordered.
Civil3D 2020
