Author Topic: Annotation Text, Selecting Ghost Text without changing anno scale  (Read 2162 times)
MSTG007
Is there a method to selecting the bigger ghost text to move instead of changing the 1" = 30' annotation text to be the bigger size? I don't want to apply the annotation text to all the other objects.
Sorry I am having a fabulous Friday of cant remember ________________ . lol
Civil3D 2020
Rob...
Re: Annotation Text, Selecting Ghost Text without changing anno scale
« Reply #1 on: February 16, 2018, 09:53:01 AM »
I find that working through the viewport that shows that scale assigned to it to be the easiest way to do this.
CAD Tech
MSTG007
« Reply #2 on: February 16, 2018, 10:03:15 AM »
But doesn't that still effect the other text(s) that are in the drawing when just trying to move one text?
Civil3D 2020
Rob...
« Reply #3 on: February 16, 2018, 10:15:39 AM »
Yes, I use grip edits, not commands.
CAD Tech
Jeff H
« Reply #4 on: February 16, 2018, 11:51:05 AM »
Make sure you have ANNOAUTOSCALE = 0 or negative value when you change the annotation scale.
ANNOAUTOSCALE
MSTG007
« Reply #5 on: February 16, 2018, 11:54:19 AM »
Is it a good practice to leave that turned off? lol. (Specially in a template) lol.
So with that turned off, I can add a scale to a piece of text, change annotation scales and nothing else will adjust except the text I assigned it too.
interesting... I know that is so 101... sorry
Civil3D 2020
Crank
« Reply #6 on: February 16, 2018, 03:15:53 PM »
Turn it off and hide the icon. ANNOAUTOSCALE is something that you don't want.
Also keep the scalelist as short as possible: In OPTIONS go to 'User Preferences' -> 'Default Scale List' and delete all scales except 1:1
Only when you need a new scale, you should add it:
(defun c:1:1 ()(MaakSchaal 1))
(defun c:1:2 ()(MaakSchaal 2))
(defun c:1:5 ()(MaakSchaal 5))
(defun c:1:10 ()(MaakSchaal 10))
(defun c:1:20 ()(MaakSchaal 20))
(defun c:1:50 ()(MaakSchaal 50))
(defun c:1:100 ()(MaakSchaal 100))
(defun c:1:200 ()(MaakSchaal 200))
(defun c:1:500 ()(MaakSchaal 500))
(defun c:1:1000 ()(MaakSchaal 1000))
(defun c:1:2000 ()(MaakSchaal 2000))
(defun c:1:5000 ()(MaakSchaal 5000))
(defun c:1:10000 ()(MaakSchaal 10000))
(defun MaakSchaal (waarde / e schaal)
(command ".undo" "be")
(setq schaal (strcat "1:" (itoa waarde)))
(setq e (getvar "EXPERT"))(setvar "EXPERT" 5)
(command ".-scalelistedit" "A" schaal schaal "Exit")
(setvar "EXPERT" e)
(if (and (zerop (getvar "TILEMODE"))(zerop (getvar "VPMAXIMIZEDSTATE"))(eq (getvar "CVPORT") 1))
(princ "\nThe scale has been added to the scalelist.")
(setvar "CANNOSCALE" schaal)
(command ".undo" "end")
To purge scales that are not in use, you can add
(command "._-scalelistedit" "_delete" "*" "_exit") to your startup-routine.
« Last Edit: February 16, 2018, 03:26:30 PM by Crank »
