Author Topic: MODEL SPACE AND LAYER MANAGER COLORS NOT SHOWING PROPERLY  (Read 2540 times)
gisdude
« on: February 14, 2018, 06:02:21 PM »
Hi all,
I'm having a problem with one drawing out of a dozen. I have all my colors set to "by layer" however all my text/linework are MOSTLY grey scaled out. I have some entities on my "ADD" LAYER which will show the color properly - in this case red. But, some lines will be greyed out and I'll have to double click them to show red, but once I de-select, they'll go back to grey.
It's like I have hit some setting/variable and I don't know how I did it because the other 10 drawings are fine. I've done recover, purge, audit, overkill. I've restarted the pc.
Any tips would be appreciated.
Re: MODEL SPACE AND LAYER MANAGER COLORS NOT SHOWING PROPERLY
« Reply #1 on: February 14, 2018, 06:44:21 PM »
Is the host layer (or layers) locked?
gisdude
« Reply #2 on: February 15, 2018, 10:15:46 AM »
Not locked, still eating at me.
I've just re-did the linework and text - it was only a couple of things, but why only the 1 file?
Thanks for the help.
dgorsman
« Reply #3 on: February 15, 2018, 10:26:50 AM »
Gone into REFEDIT accidentally?
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
gisdude
« Reply #4 on: February 15, 2018, 10:57:11 AM »
I don't have any XREF's in the drawing. So, I tried REFEDIT and I can't choose the base drawing.
gisdude
« Reply #5 on: February 15, 2018, 01:32:01 PM »
When you look at the “STYLIZATION” option, it was ON. But when you turn off, voila!.
Command: MAPDISPLAYMANAGER
Display Manager [?/Load/Update/Stylization/eXit] <eXit> :U
Updating...
Updating...
Display Manager [?/Load/Update/Stylization/eXit] <eXit> :S
Stylization [On/oFf] <On> : F
Display Manager [?/Load/Update/Stylization/eXit] <eXit> :Regenerating model.
 This was maddening.
dgorsman
« Reply #6 on: February 16, 2018, 02:27:50 PM »
If you are running something other than vanilla AutoCAD, or third-party add-ons, it helps to say so...
try {GreatPower;}
   finally
      {MasterBasics;}
