Use the Reference Manager provided with AutoCAD.
You can also use the Project setting to create a separate set of folders for searching for XREFs with missing paths.
;; find and replace/rename xrefs.;; ;; pseudo code:iterate thru xrefs. if unreferenced check name if has `mm' in name prefix name with `P1_' redo path to include `P1_' in file to xref
Quote from: Lee Mac on February 14, 2018, 08:12:37 AMUse the Reference Manager provided with AutoCAD.Thank you Lee for your reply.I tried that while searching for a solution before starting my thread here but I could not understand the way it works.
Command: REDIRCurrent REDIRMODE: Styles,Xrefs,Images,RtextFind and replace directory namesEnter old directory (use '*' for all), or ? <options>: c:\testRepace "C:\TEST" with: D:\TEST
