I'm trying to create the station of an alignment as property set data for a cogo point.
I am able to extract the cogo point easting, the cogo point northing abnd the alignment name (from the alignment handle)
However I am having trouble using the stationoffset method of the alignment.
Can I use methods in property sets?
How do I declare the variables for the station and offset?
Do I need to convert my easting and northind into a type double?
Here is where I am up to
RESULT="-"
On Error Resume Next
Set oApp=GetObject(, "AutoCAD.Application")
Set oCivilApp=oApp.GetInterfaceObject("AeccXUiLand.AeccApplication.11.0")
Set obj=oCivilApp.ActiveDocument.HandleToObject("BE7")
Dim Objstation As Double = 0.0
Dim ObjOffset As Double = 0.0
obj.StationOffset([Easting],[Northing],Objstation,ObjOffset)
RESULT=Objstation
Cheers, Rod.
