Author Topic: entmod Sectionobject - add the Destinationfile  (Read 1550 times)
Peter2
« on: February 12, 2018, 11:19:04 AM »
(Bricscad 18)
With entmake I created a SECTIONOBJECT - works fine
In code 360 "Section_Settings" I modified the code 1 ("SectionTypeSettings) with the additional "DestinationFile" - a full path.
The problem is:
- entmod returns the code and not nil. This looks great, but nevertheless it does not work.
- When I add the path via the "Properties", it works fine.
This is the code of my non working "entmod":
  1. ((-1 . <Entity name: 7ede9360>) (0 . "SECTION_SETTINGS") (5 . "43B") (330 . <Entity name: 7eddd0a0>) (100 . "AcDbSectionSettings") (90 . 2) (91 . 0) (1 . "SectionTypeSettings") (90 . 2) (91 . 17) (92 . 0) (1 . "D:\\bim-tutorial-files\\BIM tutorial files\\haalo2.dwg") (93 . 0) (3 . "SectionTypeSettingsEnd"))
This is the code after editing with "Properties":
  1. ((-1 . <Entity name: 7ede9360>) (0 . "SECTION_SETTINGS") (5 . "43B") (330 . <Entity name: 7eddd0a0>) (100 . "AcDbSectionSettings") (90 . 2) (91 . 1) (1 . "SectionTypeSettings") (90 . 2) (91 . 17) (92 . 0) (1 . "D:\\bim-tutorial-files\\BIM tutorial files\\vorher.dwg") (93 . 0) (3 . "SectionTypeSettingsEnd"))
Where is the difference or where is the problem? (The different filenames are intended)
« Last Edit: February 12, 2018, 02:17:34 PM by Peter2 »
Peter
BricsCAD V23
Dlanor
Re: entmod Sectionobject - add the Destinationfile
« Reply #1 on: February 12, 2018, 03:01:00 PM »
I don't know it's relevance but the first dotted pair shown below is different
  1. (91 . 0) (1 . "SectionTypeSettings")
  1. (91 . 1) (1 . "SectionTypeSettings"))
tschüss
Peter2
« Reply #2 on: February 12, 2018, 03:20:15 PM »
Hi Dlanor
thanks, I will take a look, but I suppose it has nothing to do with it.
In the meantime I created an ActiveX code; the first test seem to work (although the Section_Settings are a little bit mysterious for me)
  1.     (if (eq "SECTIONOBJECT" (cdr (assoc 0 (entget (entlast)))))
  2.         (progn
  3.             (setq settings_objekt (vlax-ename->vla-object (cdr (assoc 360 (entget (entlast))))))
  4.             (setq settings_objekt_methods (vlax-invoke-method settings_objekt "Getsectiontypesettings" acSectionType2dSection))
  5.             (vlax-put-property settings_objekt_methods "Destinationfile" (strcat (getvar "DWGPREFIX") name  ".dwg"))
  6.         )
  7.     )
Peter
BricsCAD V23
Dlanor
« Reply #3 on: February 13, 2018, 02:51:06 AM »
Its position outside the section settings suggests that it is a flag of some sort so may well be relevant.
http://help.autodesk.com/view/OARX/2018/ENU/?guid=GUID-8B60CBAB-B226-4A5F-ABB1-46FD8AABB928
