(Bricscad 18)
With entmake I created a SECTIONOBJECT - works fine
In code 360 "Section_Settings" I modified the code 1 ("SectionTypeSettings) with the additional "DestinationFile" - a full path.
The problem is:
- entmod returns the code and not nil. This looks great, but nevertheless it does not work.
- When I add the path via the "Properties", it works fine.
This is the code of my non working "entmod":
((-1 . <Entity name: 7ede9360>) (0 . "SECTION_SETTINGS") (5 . "43B") (330 . <Entity name: 7eddd0a0>) (100 . "AcDbSectionSettings") (90 . 2) (91 . 0) (1 . "SectionTypeSettings") (90 . 2) (91 . 17) (92 . 0) (1 . "D:\\bim-tutorial-files\\BIM tutorial files\\haalo2.dwg") (93 . 0) (3 . "SectionTypeSettingsEnd"))
This is the code after editing with "Properties":
((-1 . <Entity name: 7ede9360>) (0 . "SECTION_SETTINGS") (5 . "43B") (330 . <Entity name: 7eddd0a0>) (100 . "AcDbSectionSettings") (90 . 2) (91 . 1) (1 . "SectionTypeSettings") (90 . 2) (91 . 17) (92 . 0) (1 . "D:\\bim-tutorial-files\\BIM tutorial files\\vorher.dwg") (93 . 0) (3 . "SectionTypeSettingsEnd"))
Where is the difference or where is the problem? (The different filenames are intended)
