Author Topic: WhoHas (open) for Excel files or other types  (Read 5704 times)
Marc'Antonio Alessi
  • Marco
« on: January 31, 2018, 03:56:44 AM »
Does something like this exist for other types of files (not DWG)? Example for Excel files?
; Credits... ?
; Description:
;   return info like WhoHas command
; Arguments:
;   PatNam: fully qualified file name
; Return Values: LIST
;    "User"                              ; > UserName
;    "PC2 "                              ; > Computer Name
;    "marted́ 8 novembre 2005  16.10.45" ; > date-time
; Example:
; (setq filename (strcat (getvar "dwgprefix")  (getvar "dwgname")))
; (ALE_UtlFileWhoHas filename)
;  > ("User" "PC2 " "marted́ 8 novembre 2005  16.10.45")
(defun ALE_UtlFileWhoHas (PatNam / FilPtr TmpStr OutLst)
  (if (findfile PatNam)
      (if (setq FilPtr (open (strcat (vl-filename-directory PatNam) "\\" (vl-filename-base PatNam) ".DWL") "r"))
          (while (setq TmpStr (read-line FilPtr))
            (setq OutLst (cons TmpStr OutLst))
          (close FilPtr)
          (reverse OutLst)
rkmcswain
Re: WhoHas (open) for Excel files or other types
« Reply #1 on: February 01, 2018, 08:06:49 AM »
Excel and most other apps do not write files like AutoCAD's .DWL/.DWL2 files.
You can easily see all files that are open, and by whom, by looking on the server:
Marc'Antonio Alessi
  • Marco
« Reply #2 on: February 01, 2018, 10:27:22 AM »
Thanks, I need a solution also for files opened on "My Computer"...  ::)
rkmcswain
« Reply #3 on: February 01, 2018, 10:42:09 AM »
You have the same thing on your local PC, presuming you're running a profession version of Win7 or Win10
Marc'Antonio Alessi
  • Marco
« Reply #4 on: February 01, 2018, 11:04:15 AM »
I have tested on Win10 Pro/Home but I do not see Open Files:
« Reply #5 on: February 01, 2018, 11:04:58 AM »
Try this .. does not tell you who has it open though. Since the files are on your computer I'd imagine you already know that :P
  1. (defun _isfileopen (file / o r sf)
  2.   ;; RJP - 2.1.2018
  3.   ;; Idea translated from here: https://goo.gl/gK3UuX
  4.   ;; Use with caution NOT heavily tested
  5.   (if (and (findfile file) (setq sf (vlax-get-or-create-object "Scripting.FileSystemObject")))
  6.                      (setq o (vl-catch-all-apply 'vlax-invoke (list sf 'opentextfile file 8 0)))
  7.                    )
  8.            )
  9.            (or r (vl-catch-all-apply 'vlax-invoke (list o 'close)))
  10.            (and sf (vlax-release-object sf))
  11.     )
  12.   )
  13.   r
  14. );; (_isfileopen "C:\\myfile.xlsx")
« Last Edit: February 02, 2018, 11:22:38 AM by ronjonp »
Marc'Antonio Alessi
  • Marco
« Reply #6 on: February 01, 2018, 11:32:06 AM »
I've used this for many years and I realized now that vl-file-systime in Bricscad does not return NIL if the file is open. > ALE_UtlFileWhoHas only works with DWG ...
(defun ALE_Files_OpenP (InpFil / Countr FlgOpn WhoInf WhoStr)
  (setq Countr 5)
    ( (vl-file-systime InpFil) nil )  ;                                > return nil
    ( (logand 1 (nth 3 (DOS_FILE InpFil))) ); if the file is read only > return T
    ( (while (not FlgOpn)
          ( (or (vl-file-systime InpFil) (zerop Countr)) (setq FlgOpn T) )
          ( T
            (if (setq WhoInf (ALE_UtlFileWhoHas InpFil))
              (setq WhoStr (strcat "\n\nFile open by:  "   (car WhoInf) " " (cadr WhoInf) " " (caddr WhoInf)))
              (setq WhoStr "")
            (alert
              (strcat
                "Attention, the file " InpFil " is already open for writing."
                "\n\n" (itoa Countr) " more attempts will be made to open it."
                "\nAfter that it will be ignored."
                 WhoStr
            (setq Countr (1- Countr))
    (zerop Countr) ; > return T if the file not been closed within the 5 attempts
Marc'Antonio Alessi
  • Marco
« Reply #7 on: February 01, 2018, 11:43:47 AM »
Another:
(defun its_ok (file / dwg)
       (setq dwg (open file "a"))
    (not (close dwg))
« Reply #8 on: February 01, 2018, 11:46:57 AM »
So do you care if the file is just open or not or actually who has it open?
Marc'Antonio Alessi
  • Marco
« Reply #9 on: February 01, 2018, 12:29:21 PM »
The second: "or actually who has it open?"
I appreciate also your _isfileopen and maybe I modify my ALE_Files_OpenP with your solution (tested also in Bricscad).
« Reply #10 on: February 01, 2018, 12:43:37 PM »
Glad you could maybe use the code :) .. I'm not sure how to accomplish the 'who has it open'. Everything I'm reading on the interwebs comes back to issues with security or lack of admin.
« Reply #11 on: February 01, 2018, 12:49:29 PM »
Aside from using a generic method such as that suggested by RK above, it would depend on the filetype, for example Access database files (accdb) generate an associated .laccdb file when the database is open & locked (or partially locked) for writing - this file is a plain text format file which yields the PC name & Access username of the user who has the database open.
However, since most other filetypes are "single-user" files, I don't think they will generate their own accompanying lock files.
Marc'Antonio Alessi
  • Marco
« Reply #12 on: February 01, 2018, 01:11:11 PM »
Right now I need only for Excel files but I thought I could do something generic.
When I open a "foo.xlsx" it creates "~$foo.xlsx" which is hidden and protected ... if I make a copy and look inside the file there is written the name of the user... see att.
dgorsman
« Reply #13 on: February 01, 2018, 02:23:01 PM »
I've got an odd question: how often is it that someone else has a local file open on your own computer?  That should be so rare as to have a "whohas" type function just returning the active user.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
Marc'Antonio Alessi
  • Marco
« Reply #14 on: February 02, 2018, 06:05:02 AM »
What is your solution to know who opened an Excel file on the net? (with lisp/visuallisp)
