Author Topic: display or inspect all defined commands inside AutoCAD session  (Read 10977 times)
huiz
  • Certified Prof C3D
Re: display or inspect all defined commands inside AutoCAD session
« Reply #15 on: March 07, 2018, 03:26:14 PM »
Cool  :mrgreen:
« Reply #16 on: March 07, 2018, 08:13:39 PM »
Thanks guys!  :-)
PS: Both updated (why in code comments).
Grrr1337
(apply ''((a b c)(a b c))
vevo.bg
« Reply #18 on: March 08, 2018, 06:45:56 PM »
If you like c:vars may like what i did to abuse it in version 2.02.
(not posted yet)
O.o
« Reply #19 on: March 08, 2018, 07:00:12 PM »
Quote from: Mae West
Of all the long things I've every tried --
-- this is the most recent.
Too long to post; attached.
GDF
« Reply #20 on: March 28, 2018, 08:23:15 AM »
Awesome
Could this be modified to get only global setq vars?
GDF
« Reply #21 on: March 28, 2018, 09:32:22 AM »
Got this to work...
(defun VARLISTIT  ()
  (textpage)
  (foreach
         n  '(ARCH#LOGO ARCH#YEAR ARCH#LTYP ARCH#UNIT ARCH#DECI ARCH#DDEC ARCH#ALDR ARCH#SYMS
              ARCH#ANNO ARCH#TEXT ARCH#PROJ ARCH#DIAL ARCH#CMDN ARCH#POSX ARCH#POSY ARCH#DIAP
              ARCH#LOOP ARCH#CLAY ARCH#LREA ARCH#MECH ARCH#CIVL ARCH#_CMM ACAD#PATH ARCH#BROW
              ARCH#DIRL ARCH#CUSN ARCH#LOGF ARCH#CUSF ARCH#MASF ARCH#CSTF ARCH#BLKF ARCH#FONF
              ARCH#HELF ARCH#IMAF ARCH#PATF ARCH#PROF ARCH#SUPF ARCH#FILF ARCH#LAYF ARCH#DRAF
              ARCH#BLOF ARCH#DIMF ARCH#SYMF ARCH#ANNF ARCH#UTIF ARCH#SCAL ARCH#SCID ARCH#SCDS
              ARCH#SLTS ARCH#LTSD ARCH#PLTS ARCH#UNID ARCH#LUID ARCH#_SCF ARCH#SFIL ARCH#SLAY
              ARCH#SDRA ARCH#SBLO ARCH#SDIM ARCH#SSYM ARCH#SANN ARCH#SUTI ARCH#SARC ARCH#SSTR
              ARCH#SMEC ARCH#SELE ARCH#SCIV ARCH_XDPC ARCH#XDCN ARCH#XDAD ARCH#XDTP ARCH#XDWW
              ARCH#XDPR ARCH#PIDF ARCH#DPRE ARCH#FMSG ARCH#LMSG ARCH#WMSG ARCH#BMSG ARCH#DMSG
              ARCH#LMSG ARCH#AMSG ARCH#UMSG ARCH#NLAY ARCH#NPLT ARCH#LAYL ARCH#LAYR ARCH#IWID
              ARCH#PWID ARCH#ENTL ARCH#ENTN ARCH#HPSC ARCH#HPGP ARCH#HFAC ARCH#VHAT ARCH#PHAT
              ARCH#UNIT ARCH#CLAY ARCH#LTSS ARCH#DDEC ARCH#DECI ARCH#LTYP ARCH#LOOP ARCH#ALDR
              ARCH#TEXT ARCH#ANNO ARCH#SYMS ARCH#LREA ARCH#TXSD ARCH#TXSN ARCH#TXST ARCH#TXSS
              ARCH#TXSC ARCH#TXSA ARCH#TXNW ARCH#TXTW ARCH#TXNH ARCH#TXTH ARCH#TXTS ARCH#TXVS
              ARCH#TXFD ARCH#TXFN ARCH#TXFT ARCH#TXFS ARCH#TXFC ARCH#TXFA ARCH#SIZE ARCH#ANGL
              ARCH#JAMB ARCH#SILL ARCH#RPDX ARCH#WWID ARCH#CPNT ARCH#GPNT ARCH#STEP ARCH#SRIS
              ARCH#STRD ARCH#SCNT ARCH#SJST ARCH#SREQ ARCH#STEQ ARCH#STPT ARCH#DECK ARCH#CABW
              ARCH#BLKX ARCH#RDPX ARCH#F_ID ARCH#F_OD ARCH#DTLN ARCH#SHTN ARCH#REV# ARCH#LINI
              ARCH#LIBF ARCH#LCMD ARCH#LSLD ARCH#LACT ARCH#LCLR ARCH#_ADC ARCH#DVAR ARCH#PAUS
              ARCH#TEMP ARCH#TNUM ARCH#DOSD ARCH#DSNP ARCH#DBRK ARCH#DECP ARCH#DSTP ARCH#DALN
              ARCH#DSTP ARCH#_NIC ARCH#SSET ARCH#ELVH ARCH#ELVW ARCH#BORD ARCH#BLKN ARCH#STRG
              ARCH#UDLR ARCH#VIEW ARCH#RTOS ARCH#_STR ARCH#_DIS ARCH#_NB_ ARCH#_VH_ ARCH#NVAL
              ARCH#PROJ ARCH#PNAM ARCH#DATE ARCH#PNUM)
    (progn (print n) (princ (eval n)))))
(VARLISTIT)
[code/]
« Reply #22 on: March 28, 2018, 12:03:54 PM »
atoms-family != sysvars
That said perhaps this ...
(defun c:Globals ( / :varz :get-var-spec :get-val-spec :pad :matching-vars :matching-vals :setvars :ntos :substr :main )
    ;;  Globals.lsp
    ;;  \|//  1.01 2018-03-28
    ;;  |Oo|  © 2018 Michael Puckett Some Rights Reserved.
    ;;  |- |  mp@cadanalyst.org
    ;;  1.01  2018-03-28. MP. Initial code.
    (defun :globals ( )
        (vl-sort (atoms-family 1) '<)
    (defun :get-var-spec ( / spec )
            (eq ""
                (setq spec
                    (strcase
                        (getstring "\nEnter variable NAME search pattern <*>: ")
            spec
    (defun :get-val-spec ( / spec )
            (eq ""
                (setq spec
                    (strcase
                        (getstring "\nEnter variable VALUE search pattern <*>: ")
            spec
    (defun :pad ( text len )
        (while (< (strlen text) len)
            (setq text (strcat text " "))
        text
    (defun :matching-vars ( spec )
        (vl-remove-if-not
            (function (lambda (x) (wcmatch x spec)))
            (:globals)
    (defun :matching-vals ( vars spec )
        (vl-remove-if-not
            (function (lambda (p) (wcmatch (strcase (cadr p)) spec)))
            (mapcar
                (function
                    (lambda ( v / v$ v! )
                        (list v
                            (vl-prin1-to-string
                                (if (member
                                        (setq v! (type (setq v$ (eval (read v)))))
                                       '(exrxsubr file pagetb subr usubr vla-object)
                                    v!
                                    v$
                vars
    (defun :setvars ( lst )
        ;;  Pass the function a cons-pair or a list of cons-pairs:
        ;;  >> (setq restore (:setvars '((CMDECHO . 0)(REGENMODE 0))))
        ;;  Returns original values in the same construct:
        ;;  >> ((CMDECHO . 1) (REGENMODE . 1))
        ;;  So you can do this later:
        ;;  >> (:setvars restore)
        (mapcar
            (function
                (lambda ( p / k r )
                    (setq r (cons (setq k (car p)) (vl-catch-all-apply 'getvar (list k))))
                    (vl-catch-all-apply 'setvar (list k (cdr p)))
                    r
            (if (vl-list-length lst)
                lst
                (list lst)
    (defun :ntos ( x / r s )
        (setq
            r (:setvars '((dimzin . 8)))
            s (if (eq 'real (type x)) (rtos x 2 15) (itoa x))
            r (:setvars r)
        s
    (defun :substr ( text a b / result n )
        (setq result (substr text a b))
            (   (not (< (setq n (strlen result)) (strlen (substr text a))))
                result
            (   (wcmatch (substr text a) "(*)")
                (strcat (substr result 1 (- n 5)) " ..." (chr 41))
                (strcat (substr result 1 (- n 4)) " ...")
    (defun :main ( / restore var-spec val-spec vars-vals var val len name handle )
            (   (null (setq vars (:matching-vars (setq var-spec (:get-var-spec)))))
                (princ (strcat "\nNo variables matched pattern '" var-spec "'."))
            (   (null (setq vars-vals (:matching-vals vars (setq val-spec (:get-val-spec)))))
                (princ (strcat "\nNo values matched pattern '" val-spec "'."))
            (   (setq
                    restore (:setvars '((dimzin . 0)(luprec . 8)(auprec . 8)))
                    len     (1+ (apply 'max (mapcar 'strlen (mapcar 'car vars-vals))))
                    name    (vl-filename-mktemp "vars.txt")
                    handle  (open name "w")
                (princ
                    (strcat
                        "ACADVER: " (rtos (atof (getvar 'acadver)) 2 1)
                        ": Global variables matching (name|value) pattern ('" var-spec "'|'" val-spec "'):\n\n"
                    handle
                (foreach lst vars-vals
                    (princ
                        (strcat
                            (:pad (setq var (car lst)) len)
                                ((null (setq val (eval (read var)))) "nil")
                                ((numberp val) (:ntos val))
                                ((:substr (cadr lst) 1 80))
                            "\n"
                        handle
                (:setvars restore)
                (close handle)
                (startapp "notepad.exe" name)
    (:main)
GDF
« Reply #23 on: March 28, 2018, 12:37:54 PM »
« Reply #24 on: March 28, 2018, 03:45:37 PM »
ur welcome
Grrr1337
« Reply #25 on: March 29, 2018, 05:48:27 AM »
vevo.bg
roy_043
  • BricsCAD 18
« Reply #26 on: April 14, 2018, 03:09:00 AM »
Hanhphuc @cadtutor.net has come up with a different, more direct way, to retrieve these 'ARX' commands:
http://www.cadtutor.net/forum/showthread.php?103760-AutoCAD-built-in-command-list-with-AutoLISP&p=701145&viewfull=1#post701145
The code does not work on BricsCAD BTW. But I notice that not all commands are listed. So 'inspecting all defined commands', as per the tittle of this topic, is not possible with this approach it seems.
« Reply #27 on: April 14, 2018, 12:28:00 PM »
Thanks, interesting thread too.
