Author Topic: trigger a lisp command after "plotting"  (Read 2307 times)
dubb
« on: May 31, 2005, 06:34:31 PM »
is there a way to trigger another lisp command after running the plot command?
« Reply #1 on: May 31, 2005, 07:23:19 PM »
Sure, use the :vlr-commandended event of the Editor reactor and watch for the "Plot" command command.
dubb
« Reply #2 on: May 31, 2005, 08:01:57 PM »
HUH..?..IM UNFAMILIAR ON HOW TO USE THESE REACTORS...
« Reply #3 on: May 31, 2005, 09:14:35 PM »
OK, I couldn't recall if you had worked with reactors before. Here's an example for you:
(or jmm:plot_reactor
    (setq jmm:plot_reactor (vlr-editor-reactor nil '((:vlr-commandEnded . jmm:cmdEnd)))))
(defun jmm:cmdEnd (calling cmd)
  (princ ".....made it here....");remove this, just for testing....
  (cond ((eq "PLOT" (strcase (car cmd))) (jmm:testlisp))
;you could add other commands to track and do other things here
(defun jmm:testlisp ()
  (princ "Command was PLOT")
  ;modify the line above to call the desired lisp
  ;NOTE! The lisp you call must NOT use the Command function!
dubb
« Reply #4 on: June 01, 2005, 01:50:47 PM »
oOO..MAN..that worked perfect..thanks Jeff
daron
« Reply #5 on: June 01, 2005, 02:36:56 PM »
Just make sure you obey the NO COMMAND in the lisp you put that in.
« Reply #6 on: June 01, 2005, 03:03:39 PM »
" (or jmm:plot_reactor
    (setq jmm:plot_reactor (vlr-editor-reactor nil '((:vlr-commandEnded . jmm:cmdEnd))))) "
...Nice trick Jeff.
Edit: Darn button!?
Thats "clean" I like that.
