Author Topic: Help. vlax-curve-getDistAtPoint Error (Real World Coordinate)  (Read 6046 times)
rayakmal
« on: January 23, 2018, 03:12:53 PM »
I need to find out a distance of a point from the start of a polyline by using vlax-curve-getDistAtPoint but always return nil. Please find the attached drawing, it's in real world coordinates (UTM) Autocad 2009. Is there a way to correct this situation? Thanks in advance.
(defun C:Try ( )
  (setq obj (vlax-ename->vla-object (car (entsel))))
  (setq pt1 (getpoint "\nSelect point: \n"))
  (setq stais (vlax-curve-getDistAtPoint obj pt1))
  (princ (strcat "\n. Station: " (rtos stais 2 3) " m"))
« Last Edit: January 23, 2018, 03:46:15 PM by rayakmal »
ribarm
  • Marko Ribar, architect
Re: Help. vlax-curve-getDistAtPoint Error (Real World Coordinate)
« Reply #1 on: January 23, 2018, 03:46:00 PM »
(defun C:Try ( / obj pt1 stais )
  (setq stais (vlax-curve-getDistAtPoint obj (vlax-curve-getClosestPointTo obj (trans pt1 1 0))))
P.S. Use code tags : [ code ] Your code ... [/ code ] (inside [] no spaces...)
M.R. on Youtube
rayakmal
« Reply #2 on: January 23, 2018, 04:15:43 PM »
Yay!!! Your code works. Thanks a lot.
Can you explain why I need to add (vlax-curve-getClosestPointTo obj (trans pt1 1 0)) ?
I still don't know how to utilize your code to fix my other Lisp routine, this time with my 2nd routine I wanna find a station of a point but the point IS not on a polyline. For instance, I need to find the station of a lamp post on a curb/sidewalk (not on the road centerline).
Here's my 2nd code. This routine will also return err if I use my attached drawing (I found out yesterday It only works if the UTM coordinates are not soo distant from 0,0)
(defun c:VIS-HOR-STAIS ( /  crvobj pt closestpt Stais)
  (setq crvobj (car (entsel "\n. Select Alignment: ")))
  (setq pt (getpoint "\n. Point: "))
  (setq closestpt (vlax-curve-getclosestpointto crvobj pt))
  (command "pline" pt closestpt "")
  (setq stais (vlax-curve-getDistAtPoint (vlax-ename->vla-object crvobj) closestpt))
I changed this line
with
 (setq closestpt (vlax-curve-getclosestpointto crvobj (trans pt 1 0)))
still doesn't work.
« Last Edit: January 23, 2018, 04:30:47 PM by rayakmal »
PKENEWELL
« Reply #3 on: January 23, 2018, 05:14:00 PM »
I changed this line
with
still doesn't work.
For your 2nd question: Your need to convert the selected entity into a VLA object hence:
(setq obj (vlax-ename->vla-object (car (entsel)))) in ribarm's code.
change your line:
(setq crvobj (car (entsel "\n. Select Alignment: "))) to:
(setq crvobj (vlax-ename->vla-object (car (entsel "\n. Select Alignment: "))))
For your 1st question: (vlax-curve-getclosestpointto) ensures the selected point lies exactly on the curve with no fuzz error. When selecting using (entsel) the point the cursor picks may not be exactly on the curve. Also - (trans) converts the point from the current UCS to the WCS.
EDIT: Correction: Your not using the picked point in (entsel), but (getpoint). However - there may still be errors in the point location depending on object snap, etc.
That being said - your could shorten the picking by doing the following IF the object snap exact point is not needed (the user could still use an osnap override such as "nea" or "mid", etc.):
(if (setq sel (entsel "\nSelect Alignment at the point needed: "))
   (setq crvobj (vlax-ename->vlax-object (car sel))
            pt (cadr sel)
« Last Edit: January 23, 2018, 05:28:20 PM by PKENEWELL »
"When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it." - Theodore Roosevelt
roy_043
  • BricsCAD 18
« Reply #4 on: January 23, 2018, 05:42:37 PM »
Two things:
1.
The vlax-curve-* functions also accept enames.
2.
To avoid unexpected results it can be a good idea to use (osnap pt "_nea") to ensure the selected point as actually on the entity before using vlax-curve-getclosestpointto.
PKENEWELL
« Reply #5 on: January 23, 2018, 06:03:19 PM »
Two things:
1.
2.
1. Interesting - I did not realize that. guess I should read up on those a bit more. Makes me wonder what problem the OP is having then. Might be better just to have a sample drawing to work with.
2. I agree.
rayakmal
« Reply #6 on: January 23, 2018, 06:44:45 PM »
Two things:
2. I agree.
The 1st problem was solved (Picked point is on the polyline). The 2nd problem is different, this time I pick a point not on the polyline, let's say 3 units away from the polyline and I need to find its station (projected to the polyline).
« Last Edit: January 24, 2018, 12:20:30 AM by rayakmal »
PKENEWELL
« Reply #7 on: January 24, 2018, 01:20:42 AM »
The 2nd problem is different, this time I pick point not on the polyline, let's say 3 units away from the polyline and I need to find its station (projected to the polyline).
OK. A bit more information is needed then. What is the projection vector to the selected curve? Perpendicular (the closest point)? Orthographic? Nearest Vertex?
An idea for coding this to the perpendicular would be to get the closest intersect point perpendicular to the segment (note: I'm doing this without being able to test at the moment - so forgive any typos):
;; untested snippet
(if (and
         (setq sel (entsel "\nSelect Alignment: "))
         (setq  pt (getpoint "\nSelect Point: "))
   (setq spt1 (osnap (cadr sel) "nea") ; get the nearest point to the entity pick
         spt2 (osnap spt1 "end") ; get the nearest endpoint to the entity pick
          ang (angle spt1 spt2) ; determine the angle of the segment
          int (inters spt1 spt2 pt (polar pt (+ ang (/ pi 2)) 1.0) nil) ; get the intersection with the point and the curve, at perp. angle.
          int (if (osnap int "nea") int spt2) ; If no intersection is found, set to the nearest endpoint found. NOTE this requires the user to select the curve at a location nearest to the projection.
          ent (car sel)
        stais (vlax-curve-getDistAtPoint ent (vlax-curve-getClosestPointTo ent (trans int 1 0)))
This method would require the user to select the curve segment (and hence the point on the segment from "(cadr sel)") as close to the projection point as possible. It's late so I'll test this out tomorrow. Might be a better way to do this, but it is to much code than I have time for at the moment.
EDIT: Tested this and found a couple mistakes so I updated the code. Seems to work OK now.
EDIT2: Removed an extra parenthesis
« Last Edit: January 26, 2018, 05:22:26 PM by PKENEWELL »
ribarm
« Reply #8 on: January 24, 2018, 07:37:22 AM »
@PKENEWELL
(polar) function needs 3 arguments : reference point, angle in radians and distance from point... You forgot to supply distance...
M.R. on Youtube
PKENEWELL
« Reply #9 on: January 24, 2018, 09:34:51 AM »
@PKENEWELL
Thanks Mario. I was up too late last night doing that. Corrected.
rayakmal
« Reply #10 on: January 24, 2018, 05:56:27 PM »
Thanks a lot Guys.
Sorry for the late reply. I'll test your code and let you know.
Btw. "Projected" = the closest distance to a polyline (and I always work with 2D Polyline).
rayakmal
« Reply #11 on: January 25, 2018, 08:36:08 AM »
;; untested snippet
(if (and
          ent (car sel)
        stais (vlax-curve-getDistAtPoint ent (vlax-curve-getClosestPointTo ent (trans int 1 0))))
I tried your code with my drawing, it won't work. Thanks anyway, I appreciate your help.
Here's I attached a new drawing to illustrate what I'm trying to accomplished with the 2nd code, what I want is to find the stations of sign posts along the road.
PKENEWELL
« Reply #12 on: January 26, 2018, 05:12:12 PM »
Hmmm . I opened you test drawing and chose a location about @ approx. 290 and below your alignment. The code returned a value of 291.083, which is correct to where I approximately picked. Then I stared a LINE using (command "._line" "_non" int pause) and it gave me the location I wanted. Are you sure you are using it correctly?
PKENEWELL
« Reply #13 on: January 26, 2018, 05:25:10 PM »
OOPS OK. I discovered I have an extra Parenthesis in my code, but somehow it was still working when I copied and pasted the snippet. I have corrected my above code.
Here - I have written a new version of your function:
(defun c:VIS-HOR-STAIS ( /  sel pt spt1 spt2 ang int ent stais)
   (if (and
             ent (car sel)
   (command "._line" "_non" int "_non" (polar int (+ ang (* pi 1.5)) (distance pt int)) "")
Give this a try - should work.
EDIT: I updated the line command so it connects a line back to the picked point.
« Last Edit: January 26, 2018, 09:34:48 PM by PKENEWELL »
rayakmal
« Reply #14 on: January 27, 2018, 12:10:58 AM »
   (if (and
             ent (car sel)
YES, it works if I pick a point near a tangent (a straight line) but when I pick a point near a curve, it won't.
