Author Topic: What can remove a dictionary from a drawing?  (Read 1964 times)
Atook
  • AKA Tim
« on: January 23, 2018, 01:17:48 PM »
Just had a weird bug show up in my app where a dictionary that was created on the NOD via .NET disappeared. Two other dictionaries created with the same methods remained, so I don't think it's a problem with the dictionary creation/saving code.
I'm trying to figure out how this could have happened, I tried the purge command, but that didn't do it.
I imagine WBLOCK could do it, but only one of the three dictionaries was removed. I would imagine WBLOCK would remove all the dictionaries, keeping only drawing entities.
The drawing may have been opened in both AutoCAD and Bricscad, but again, I've tested that a few times and it hasn't been a problem.
Any ideas?
dgorsman
Re: What can remove a dictionary from a drawing?
« Reply #1 on: January 23, 2018, 02:43:31 PM »
UNDO?
Did it go missing after closing the drawing/application, or was this in the same session?
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
Atook
  • AKA Tim
« Reply #2 on: January 23, 2018, 02:57:26 PM »
Different sessions.
« Reply #3 on: January 23, 2018, 03:24:46 PM »
