Author Topic: Flatten Not working on Blocks  (Read 1360 times)
mailmaverick
« on: January 23, 2018, 07:13:45 AM »
I have used Express Tools FLATTEN command as well as
      (command "MOVE" ss "" "0,0,0" "0,0,1e99")
      (command "MOVE" ss "" "0,0,0" "0,0,-1e99")
for moving my objects to Zero Elevation.
It works fine for all objects except Blocks. Any way to put all objects within a block to Zero elevation ?
lamarn
Re: Flatten Not working on Blocks
« Reply #1 on: January 23, 2018, 07:17:30 AM »
No easy fix imo.
Normal procedue. Refedit and fix in manually, isn't that an option?
mailmaverick
« Reply #2 on: January 23, 2018, 07:25:08 AM »
No easy fix imo.
We get drawings from client which contains thousands of entities and blocks, it is very difficult to modify each one of them manually.
lamarn
« Reply #3 on: January 23, 2018, 08:44:48 AM »
post parts of an example.
Maybe the blocks are not so complex to run it with some script or lisp or
« Reply #4 on: January 23, 2018, 08:46:51 AM »
Have you tried THIS ?
