(command "_.purge" "_Zero" "_.purge" "_Empty")
(vlax-for b (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-acad-object) ) ) (vlax-for o b (if (or (and (vlax-property-available-p o 'Textstring) (= "" (vl-string-trim " \t\n" (vlax-get o 'Textstring))) ) (and (vlax-property-available-p o 'Length) (= 0. (vlax-get o 'Length)) ) ) (vla-Delete o) ) ))
Code: [Select](command "_.purge" "_Zero" "_.purge" "_Empty")
