Author Topic: Combined Shape File  (Read 3611 times)
nobody
  • .net stuff
Combined Shape File
« on: January 22, 2018, 12:42:13 PM »
I don't think it is, but is it possible to export a shapefile that contains everything in one file (polylines, points, etc)?
Thanks!
Re: Combined Shape File
« Reply #1 on: January 22, 2018, 03:39:13 PM »
Thanks!
Not directly out of MAP. (as a SHP file)
However one can do it as and ESRI COVERAGE file or ESRI e00 file type.
However not all programs that are looking for a SHP file can import those other two as well.
« Last Edit: January 22, 2018, 03:51:11 PM by mjfarrell »
« Reply #2 on: January 22, 2018, 03:51:38 PM »
bump....for revision above AAACK.....no that doesn't work either....
back to original answer....NOT DIRECTLY OUT OF AUTOCAD MAP
« Last Edit: January 22, 2018, 04:00:37 PM by mjfarrell »
nobody
  • .net stuff
« Reply #3 on: January 23, 2018, 07:09:08 PM »
Thanks!
kirby
« Reply #4 on: January 24, 2018, 10:27:09 AM »
Just an FYI from ESRI Shapefile specification
https://www.esri.com/library/whitepapers/pdfs/shapefile.pdf
All the non-Null shapes in a shapefile are required to be of the same shape type. The
values for shape type are as follows:
Value Shape Type
0 Null Shape
1 Point
3 PolyLine
5 Polygon
8 MultiPoint
11 PointZ
13 PolyLineZ
15 PolygonZ
18 MultiPointZ
21 PointM
23 PolyLineM
25 PolygonM
28 MultiPointM
31 MultiPatch
