Author Topic: Move these threads to General Programming  (Read 4713 times)
« on: January 19, 2018, 02:17:22 PM »
Would anyone be upset if I moved all the topics in this board to General Programming ( http://www.theswamp.org/index.php?board=20.0 ) and remove ARX Programming altogether?
MickD
  • (x-in)->[process]->(y-out)
Re: Move these threads to General Programming
« Reply #1 on: January 19, 2018, 04:48:49 PM »
either there or the .net forum as some of it is relevant to .net ARX?
Wherever they are, a quick search for 'ObjectARX' or 'ARX' should bring them up though.
Lao Tzu: “To attain knowledge, add things
every day; to obtain wisdom, remove things every day.”
kdub
  • SuperMod
« Reply #2 on: January 20, 2018, 09:36:42 PM »
I think a folder in General Programming ( or even just dumped in General Programming)
called Kerry in my other life
#ridesober
Alexander Rivilis
  • Programmer from Kyiv (Ukraine)
« Reply #3 on: January 29, 2018, 03:36:51 PM »
I would be upset.
It's Alive!
  • BricsCAD
  • AKA Daniel
« Reply #4 on: January 30, 2018, 12:11:20 AM »
I would be upset.
VVeli
« Reply #5 on: February 14, 2018, 03:14:33 AM »
Why you need to change that?
Br. Veli
