Author Topic: Open excel file (*.xlsx) with autocad command  (Read 3561 times)
pedroantonio
« on: January 12, 2018, 04:03:51 PM »
Hi .I have an (*.xlsx) file in a folder with the name Test in C drive. I am using Autocad 2017 and Office  2016
I write the command
^c^c(startapp C:\\Program Files (x86)\\Microsoft Office\\root\\Office16\" \"C:\\Test\\My test.xlsx\"")
and gives me this error
Unknown command STARTAPP
Any ideas
« Last Edit: January 12, 2018, 04:07:04 PM by Topographer »
dubb
Re: Open excel file (*.xlsx) with autocad command
« Reply #1 on: January 12, 2018, 04:34:01 PM »
Try this
(startapp "C:/Program Files (x86)/Microsoft Office/root/Office16/excel.exe" "\"C:\\Test\\My test.xlsx\"")
I write the command
Any ideas
ChrisCarlson
« Reply #2 on: January 12, 2018, 04:34:31 PM »
Well, the full path is required, including excel.exe. Second, the unknown command is triggering as it's the default error that the command did not run properly.
« Reply #3 on: January 12, 2018, 04:51:53 PM »
Alternatively:
  1. (defun _openfile (file / sh)
  2.   (setq sh (vlax-get-or-create-object "Shell.Application"))
  3. )
  4. (_openfile "C:\\Test\\My test.xlsx")
Grrr1337
« Reply #4 on: January 12, 2018, 04:56:26 PM »
This was suggested by Lee Mac:
  1. (startapp (vl-registry-read (strcat "HKEY_CLASSES_ROOT\\" (vl-registry-read "HKEY_CLASSES_ROOT\\.xls") "\\shell\\new\\command")))
(apply ''((a b c)(a b c))
vevo.bg
pedroantonio
« Reply #5 on: January 12, 2018, 05:11:45 PM »
Thank you for the help
