Author Topic: Recursive function on the fly  (Read 5851 times)
Grrr1337
« on: January 09, 2018, 06:58:59 PM »
Hi guys, just wanted to leave this here - you might find it interesting:
  1. _$ (
  2.   (setq groupby3
  3.     (lambda (L / r)
  4.       (repeat 3 (and L (setq r (cons (car L) r))) (setq L (cdr L)) r)
  5.       (if L (cons (reverse r) (groupby3 L)) (progn (setq groupby3 nil) (list (reverse r))))
  6.     )
  7.   )
  8.   '(0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16)
  9. )
  10. ((0 1 2) (3 4 5) (6 7 8) (9 10 11) (12 13 14) (15 16))
  11. _$ groupby3
  12. nil
(apply ''((a b c)(a b c))
vevo.bg
roy_043
  • BricsCAD 18
Re: Recursive function on the fly
« Reply #1 on: January 10, 2018, 04:23:43 AM »
Two minor improvements:
  1. (
  2.   (setq groupby3
  3.     (lambda (L / r)
  4.       (repeat 3 (and L (setq r (cons (car L) r)) (setq L (cdr L))))
  6.     )
  7.   )
  9. )
Maybe this coding style is just too confusing? :evil:
Note that because of all the setq's and the use of recursion the code will not be particularly fast.
« Reply #2 on: January 10, 2018, 07:14:48 AM »
Try a tail-recursive syntax.
Grrr1337
« Reply #3 on: January 10, 2018, 09:22:46 AM »
Yes - it looks confusing,
But I think if a proper comment description is written about the recursive function (about its inputs/return, aswell note that it localises itself) then it won't be required to understand it, just use it.
Sorry I didn't include any - my point was to share the overall technique, since it looks interesting.
Thanks for mentioning, however any recursive routine could be implemented (the one I used was just to demonstrate something practical for that technique).
Not sure if this is tail-recursion (but its getting more confusing) :
  1. _$ (
  2.   (setq
  3.     from_right
  4.     (lambda ( L )
  5.       (if (print (setq L (reverse (cdr (reverse L))))) (from_left L) (setq from_right nil from_left nil))
  6.     )
  7.     from_left
  8.     (lambda ( L )
  9.       (if (print (setq L (cdr L))) (from_right L) (setq from_left nil from_right nil))
  10.     )
  11.   )
  12.   '(1 2 3 4 5 6 7 8 9)
  13. )
  14.
  15. (2 3 4 5 6 7 8 9)
  16. (2 3 4 5 6 7 8)
  17. (3 4 5 6 7 8)
  18. (3 4 5 6 7)
  19. (4 5 6 7)
  20. (4 5 6)
  21. (5 6)
  22. (5)
  23. nil nil
  24. _$ from_right
  25. nil
  26. _$ from_left
  27. nil
  28.
BTW I'm a dummy at understanding recursions - just good enough to write the linear ones.
So please share your findings to build-up opinions about this.
One additional thing from me:
For that technique, the recursive function must be error-proof, since it won't be able to undefine itself when error occurs.
Should "recursive annonymous function" be a more appropriate name?  :tongue2:
« Last Edit: January 10, 2018, 09:26:39 AM by Grrr1337 »
vevo.bg
« Reply #4 on: January 10, 2018, 09:46:32 AM »
See the examples on the wikipedia page for an example of a tail-recursive function.
[ https://en.wikipedia.org/wiki/Tail_call#Example_programs ]
No, because it is named. You are just employing syntactic sugaring techniques. I posted a snip of a conversation I was having with MP which covers this topic, for you once (did you not read it?).
MP, sorry for posting something you wrote out of context but I had the snip in my files and no link. Also, you explain things...gooder.
If you feel as though you're a `dummy at these things', you really should read a good solid book on programing. Structure and Interpretation of Computer Programs is what I started with.
VovKa
  • Ukraine
« Reply #5 on: January 10, 2018, 10:22:02 AM »
compare
(setq from_right 1 from_left 2)
((setq from_right (lambda (L)
      (from_left L)
    from_left nil
       from_left  (lambda (L)
      (from_right L)
      (setq from_left nil
    from_right nil
(print from_right)
(print from_left)
with
((lambda (L from_right from_left) (from_left L))
  (lambda (L)
      (from_left L)
  (lambda (L)
      (from_right L)
(print from_right)
(print from_left)
« Reply #6 on: January 10, 2018, 10:25:46 AM »
Should "syntax masturbation" be a more appropriate name?
fixed
roy_043
  • BricsCAD 18
« Reply #7 on: January 10, 2018, 11:26:55 AM »
My point actually is that by condensing the code to fit on a limited number of lines you are confusing yourself, let alone the readers of your code. Just look at your (repeat ...) expression.
roy_043
  • BricsCAD 18
« Reply #8 on: January 10, 2018, 02:21:36 PM »
Does AutoLisp support tail recursion? Using the example from the Wiki link I would say that BricsCAD Lisp does not.
« Reply #9 on: January 10, 2018, 03:31:50 PM »
Example using tail recursion:
  1. (   (lambda ( rec lst ) (rec lst nil))
  2.     (lambda ( lst acc )
  3.         (if lst
  4.             (rec (cdddr lst) (cons (mapcar '(lambda ( a b ) a) lst '(0 1 2)) acc))
  5.             (reverse acc)
  6.         )
  7.     )
  9. )
  1. ((0 1 2) (3 4 5) (6 7 8) (9 10 11) (12 13 14) (15 16))
AFAIK, tail recursion isn't optimised in AutoLISP as it is in other languages.
« Reply #10 on: January 10, 2018, 03:55:14 PM »
No it's not (from what I remember).
(defun factorial (n)
 (if (= n 1)
    1
    (* n (factorial (- n 1)))))
Command: (factorial 5)
Entering (FACTORIAL 5)
  Entering (FACTORIAL 4)
    Entering (FACTORIAL 3)
      Entering (FACTORIAL 2)
        Entering (FACTORIAL 1)
        Result:  1
      Result:  2
    Result:  6
  Result:  24
Result:  120
120
  (fact-iter 1 n))
(defun fact-iter (product n)
  (if (< n 2)
      product
      (fact-iter (* product n)
                 (- n 1))))
  Entering (FACT-ITER 1 5)
    Entering (FACT-ITER 5 4)
      Entering (FACT-ITER 20 3)
        Entering (FACT-ITER 60 2)
          Entering (FACT-ITER 120 1)
          Result:  120
        Result:  120
      Result:  120
    Result:  120
  Result:  120
Result:  120
« Reply #11 on: January 10, 2018, 04:38:46 PM »
« Reply #12 on: January 10, 2018, 04:43:52 PM »
Why?
Why isn't it optimized? ...*shrug* I don't have any more knowledge of the inside workings of the interpreter than you do (any more then observations).
« Reply #13 on: January 10, 2018, 04:45:03 PM »
Why?
Apologies, I misunderstood your response - I thought you were disputing the tail-recursiveness of the function, as opposed to agreeing with the lack of optimisation.
« Reply #14 on: January 10, 2018, 04:50:25 PM »
Ah. No problem.
I didn't look at your code; I trust your judgement as to its operation. ...I only made the suggestion to use a tail-recursive format for an exercise and a bit of a lesson into recursion 101. And, to eventually drive home the point about iterative functions and proper algorithm design.
