Author Topic: Create closed boundary in a closed area.  (Read 4196 times)
Coder
« on: January 07, 2018, 01:10:39 PM »
Hello everyone.
I am trying to create a closed polyline ( boundary ) from the closed areas along two polylines but I don't have enough experience in coding to do this.
I need to select the two cyan polylines then create closed polylines from the internal closed areas as indicated in the red and green objects in the attached image.
Any ideas or codes or a direction will be welcome.
Thank you.
ribarm
  • Marko Ribar, architect
Re: Create closed boundary in a closed area.
« Reply #1 on: January 07, 2018, 01:55:31 PM »
You can try Superboundary plugin from Debalance at http://www.superboundary.com/ ... I don't quite know, but I think that latest version is little buggy, so try something earlier if you can't make it... Anyway you'll have to manually select only those boundaries that are between your cyan polylines...
M.R. on Youtube
« Reply #2 on: January 07, 2018, 01:59:01 PM »
Coder
« Reply #3 on: January 07, 2018, 02:02:05 PM »
Thank you marko for your reply to my thread.
I am looking forward to make it working with lisp codes, do you have any suggestion other than picking a point in every closed area?
ribarm
« Reply #4 on: January 07, 2018, 02:20:31 PM »
Explore Lee's suggestion...
M.R. on Youtube
Coder
« Reply #5 on: January 07, 2018, 02:30:07 PM »
See this thread:
https://www.theswamp.org/index.php?topic=10371.0;all
Thank you Lee for your input.
your program is very good but it asks the user to select objects to create the boundary while I need to select the two polylines and create closed boundaries in between.
Could the program be modified to do what I am looking forward?
I think I need to study the codes in details.
Thank you.
Thank you.
Grrr1337
« Reply #6 on: January 07, 2018, 06:49:48 PM »
Looks achievable, using Lee's bbpoly and when the geometry is of closed lwpolylines. (including the road geometry)
Since in some cases for open curves/lines the bbpoly crashes.
« Last Edit: January 07, 2018, 06:57:04 PM by Grrr1337 »
(apply ''((a b c)(a b c))
vevo.bg
Angelina
  • Mosquito
« Reply #7 on: February 25, 2021, 09:20:49 PM »
Grrr1337
Will you share this lisp with me, I tried to use bbpoly lisp but it doesn't work as you showed in gif. You can also email me.
angelinabrown0123@gmail.com
