I am trying to understand (prob a noob thing) how dimension style overrides work.
I have a detail that has its own Style. However, in some drawings I insert the detail and go to explode it to edit it, the test and dim style is no correct. (goes big, etc.)
I have a routine I try to use, but it always shows up in the dimension style manager under the Style Name as <style override>
(command "-dimstyle" "Variables" "DETL" "DIMADEC" "4" "DIMASZ" "0.1" "DIMAUNIT" "1" "DIMCEN" "0.00" "DIMCLRT" "256" "DIMDEC" "2" "DIMEXE" "0.09" "DIMGAP" "0.04" "DIMTAD" "1" "DIMTDEC"
"2" "DIMTIH" "OFF" "DIMTOH" "OFF" "DIMTXSTY" "DETL" "DIMTXT" "0.07" "-dimstyle" "apply" "all" "")
However, if I do not use the routine, and manually edit each field in the Dimension Style Manager. then explode the detail, everything adjusts normally.
Long story short. I use the same detail in some drawings, and explode it to edit and everything works as it should. I use the same detail in other drawings and when I explode it to edit, it does not show correctly and I have to edit all the fields.
Any help would be great!
