Author Topic: Overkill not working with this file  (Read 2541 times)
HasanCAD
« on: December 24, 2017, 02:37:14 AM »
File attached
Why is this?!?!
Crank
Re: Overkill not working with this file
« Reply #1 on: December 26, 2017, 08:49:16 AM »
OVERKILL removes duplicate or overlapping lines, arcs, and polylines. Also, combines partially overlapping or contiguous ones.
It doesn't remove duplicate blocks or text.
Kyle Reese
« Reply #2 on: December 26, 2017, 12:52:18 PM »
With a little effort I'm sure you can find lisp routines that will 1) remove duplicate blocks and 2) remove duplicate text entities.  I doubt you'll find one that does both.
Ex. - NODUPTEXT.lsp by Jiro Ramji
HasanCAD
« Reply #3 on: December 27, 2017, 04:41:31 AM »
I tested OVERKILL it removes blocks, Mtext and text
Iam using AutoCAD2014
ChrisCarlson
« Reply #4 on: December 27, 2017, 09:53:43 AM »
The blocks are different names, overkill will only delete the underlying block if it is the same name.
cap-518
cap-454
MSTG007
« Reply #5 on: January 02, 2018, 07:27:53 AM »
Is there another type of "overkill" commands out there?
Just a question, but does overkill work really on entities that are on top of eachother with the same layer name only? I think I tried once to do it with multiple layers and it would not work.
Civil3D 2020
Rob...
« Reply #6 on: January 02, 2018, 08:04:49 AM »
Overkill can ignore some properties:
CAD Tech
