Author Topic: ;| Inline piped comments|; and compiling to FAS and DES  (Read 2361 times)
Peter2
« on: December 18, 2017, 08:56:03 AM »
AutoCAD 2018 help writes:
;| Inline |;
The single-line comment appears after formatting as any other expression; the multiple-line comment appears starting at a new line
So this should be a valid code:
  1.  (princ "\nLet's beginn.")
  2. ;| I start the comment,
  3. continue it in second line and
  4. finish it in third line with the ending pipe |;
  5. (princ "\nGreat job!")
But I heard that this kind of comment could create problems when compiled to FAS and to DES.
Who can confirm or not confirm these compilation issues?
Peter
BricsCAD V23
ribarm
  • Marko Ribar, architect
Re: ;| Inline piped comments|; and compiling to FAS and DES
« Reply #1 on: December 18, 2017, 09:31:35 AM »
I haven't tested, but if you heard rumors, I would check with this :
  2. ;|
  3. I start the comment,
  4. continue it in second line and
  5. finish it in third line with the ending pipe
  6. |;
  7. (princ "\nGreat job!")
  8.
So basically you have to replace all ;| with \n;|\n and all |; with \n|;\n
M.R. on Youtube
Marc'Antonio Alessi
  • Marco
« Reply #2 on: December 18, 2017, 09:48:58 AM »
[/size][/font][/color]
I found problems compiling des if there is no closing of the paragraph  "|;" at the end of the file, no problems with fas-
Peter2
« Reply #3 on: December 20, 2017, 02:46:23 AM »
Thanks to both posters. In the meanwhile I found another information.
  1. There has been an issue with double quotes in inline comments in DESCoder.exe V2.2, but that has been fixed a long time ago.
But nevertheless I will convert this kind of comments if I found some; personally I never used it.
Peter
BricsCAD V23
