Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
(Challenge) Max Sum of Sub Array
« previous
next »
Print
Pages:
1
2
All
Go Down
Author
Topic: (Challenge) Max Sum of Sub Array (Read 3470 times)
Seagull
London, England
WWW
Re: (Challenge) Max Sum of Sub Array
Reply #15 on:
December 09, 2017, 10:22:29 AM »
Extending Roy's method, rather than testing for negation, I think the loop could be reduced to testing whether the next element improves the overall sum, i.e.:
Code - Auto/Visual Lisp:
[Select]
defun
LM_maxsublist
lst
idx rtn tmp
setq
rtn
list
car
lst
0
0
tmp rtn
idx
1
foreach
itm
cdr
lst
if
car
tmp
itm
itm
setq
tmp
list
itm idx idx
setq
tmp
list
car
tmp
itm
cadr
tmp
idx
if
car
rtn
car
tmp
setq
rtn tmp
setq
idx
1+
idx
rtn
[Select]
_$
LM_maxsublist '
1
9
6
5
9
3
2
7
4
5
8
2
6
12
10
12
_$
LM_maxsublist '
1
9
6
5
9
3
2
7
4
5
8
2
12
6
24
10
13
_$
LM_maxsublist '
2
2
2
3
3
3
3
Logged
Lee Mac Programming
Twitter
Exchange App Store
Administrator
Seagull
Reply #16 on:
December 09, 2017, 08:33:22 PM »
Please add comments to your code entries.
Logged
TheSwamp.org
(serving the CAD community since 2003)
roy_043
Water Moccasin
BricsCAD 18
Reply #17 on:
December 10, 2017, 04:42:49 AM »
Lee's code shows that I have been seriously overthinking this.
Of course now I'll have to do some more thinking...
Logged
Seagull
London, England
WWW
Reply #18 on:
December 10, 2017, 07:01:25 AM »
Quote from: John Kaul (Se7en) on December 09, 2017, 08:33:22 PM
A commented version:
[Select]
defun
LM_maxsublist
lst
idx rtn tmp
;; Define function and declare arguments & local variables
;; Initialise variables
setq
;; 'rtn' holds the value that will eventually be returned by the function
rtn
list
car
lst
0
0
;; 'tmp' holds the comparison value to test whether each item improves the overall sum, initialised to the same value as 'rtn'
tmp rtn
;; Index variable initialised to 1 as we've already processed the first item
idx
1
;; end setq
;; For every other item in the list
foreach
itm
cdr
lst
;; If the item is greater than the current sum plus the item
if
car
tmp
itm
itm
;; Then all previous items would contribute negatively to the sum, so start the sublist at this item
setq
tmp
list
itm idx idx
;; Else add this item to the current sum and update the upper index
setq
tmp
list
car
tmp
itm
cadr
tmp
idx
;; end if
;; If the current sum is greater than our current maximum
if
car
rtn
car
tmp
;; Then update the current maximum as we've found something better
setq
rtn tmp
;; end if
;; Increment the index variable for each item processed
setq
idx
1+
idx
;; end foreach
;; Return the maximum sum obtained and corresponding indexes
rtn
;; end defun
Logged
Lee Mac Programming
Twitter
Exchange App Store
Print
Pages:
1
2
All
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
