Author Topic: Vertical Curve Information Between profile Views  (Read 4226 times)
nobody
  • .net stuff
« on: December 01, 2017, 05:03:06 PM »
Anyone know how to prevent this?
Re: Vertical Curve Information Between profile Views
« Reply #1 on: December 04, 2017, 08:38:56 AM »
uh....just a guess  don't label them?
Actually; I need a little more information to render a good answer....
is that TWO different profiles, in the same view or what?
sljohnson
« Reply #2 on: December 04, 2017, 11:02:06 AM »
Depends on how the style is defined. Try checking the "Start point anchor point" and "End point anchor point" settings. Ours are set to "Anchor Curve Start in View Dimension" instead of "Anchor Curve Start Dimension" and likewise for the end point.
EDIT: Check the Dimension component of the vertical curve label style.
nobody
  • .net stuff
« Reply #3 on: December 04, 2017, 07:45:12 PM »
vertical curve that's in the middle of two profile views (same alignment)
nobody
  • .net stuff
« Reply #4 on: December 04, 2017, 07:47:55 PM »
thank you, that was the key "anchor curve dimension start in view"...key part was the "in view"
MSTG007
« Reply #5 on: December 05, 2017, 07:39:09 AM »
So in the default Civil3D template we can update that piece and it should now look normal on small crests and sags?
Civil3D 2020
« Reply #6 on: December 05, 2017, 08:39:22 AM »
yes
sljohnson
« Reply #7 on: December 05, 2017, 12:53:03 PM »
Also, you may want to create a child style of your typical vertical curve style that includes something like, "Length of Vertical Curve Shown," or some such verbiage, with the field of the that partial length.
Best,
Shannon
